Long road to home.
   / Long road to home.
A few of you have asked for my thoughts and observations regarding the Perma-Column poles I used. Well....
The added about 10% to the cost of materials. They are very heavy. There's no wood in the ground to rot.
I went with the factory assembled poles. This meant the 2x6's were glued into three ply posts for the PC6300 and four ply for the PC6400 models in a controled environment. Also this allowed the butt joints to be finger jointed and glue. The posts where then milled to be square and uniform dimensions. This created a very straight pole.
Attaching treated lumber to the lower concrete section was no big deal. I used a Milwaukee corded 1/2" hammer drill with the recommended 3/16" masonry bit. The split drive nails were fairly easy to drive with a 20oz. hammer.
Attaching girts to the wood portion was quick work for the nail gun. However, the wood portion is smaller then the concrete section on two opposite sides. So because I installed the poles all in same direction to accommodate the headers the two sidewalls required a couple extra steps. To avoid nailing through the 3/8" brackets you need to place a 2x6 nail on the post. Your first grit, at 24" o.c., is then nailed to the added 2x6.
All remaining girts and headers will need a piece of 3/4" plywood between them and the poles. This will maintain the proper plain, creating a vertically straight wall. Remember this is was because of the header layout. I probably could have oriented the poles so to minimize this step, just didn't think of it till after poles where in.
Overall I would say I am quite pleased with the Perma-Column product. Would I use them again, definitely (no I am not building another barn).
Hope this answers everyone's curiosity
   / Long road to home. #162
Lee,
I am loving watching the barn build. I wasn't expecting a barn build in this thread and it is a pleasant surprise. You are doing great work.
Obed
   / Long road to home. #164
Did Perma Column spec the size columns needed?
No. If you go to their website the is a chart you can use to select the post size.
What, are you building cabinets? :) Pretty amazing. Looking good.
Obed
Thanks Obed. I am very happy with how this is turning out. Funny you mentioned cabinets, that is what the second floor is slated for. All the cabinetry for the house is going to be made up there.
   / Long road to home. #167
A man with a plan!
Will you have some sort of equipment lift to make it easy to raise woodworking stuff up, and lower finished cabinets down?
I am going to frame a 6' door opening above the middle OHD. When time comes to start moving big things up there I will install the door. Still considering my options for some kind of lifting mechanism.
   / Long road to home. #169
A 12v winch might do it, and it could be used with your tractor/truck/whatever beyond power cord range. Some of those have pretty high pull weight ratings. You could chain up heavy things like a table saw, and use a wood platform for lighter things that would not take chains well.
If you put a lift hole trap door in the floor of the second story, you could back in with a truck or trailer and lift directly off those. A door in the exterior wall might force you to use an I-beam track with a rolling winch or chainfall.
The weather has improved, been cold and raining last two days. It was actually snowing yesterday morning. I did manage to be a little productive though. The mower is back up and running thanks to my wife's uncle. Also got some mud put on the bathroom walls. That made my wife happy.
Barn update.
Today I put up the LVL'S that frame out the stairway and the first floor Joist. That took most of the morning as I was alone today. After lunch I set up a pic and put up all the joist hangers for tomorrow. Thank God my cousin let me borrow his hanger gun. Way easier to just pull the trigger then use a palm nailer, or worse, a hammer.
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
John Deere 60 Tractor (A59814)
John Deere 60...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Power Wise Golf Cart Charger (A57454)
Power Wise Golf...
Pickup Truck (A59230)
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
