Long vs short bed truck when pulling a gooseneck?
   / Long vs short bed truck when pulling a gooseneck? #22
Here in Michigan, you can obtain a 'Recreational Doubles Endorsement' on your license that allows you to pull, for example, a fifth wheel travel trailer, plus another trailer (like a boat) hitched to the back of the fifth wheel.
It also applies to a bumper pull outfit.
There are some really long outfits plying the roads up here.......:)
Everytime I see one, I allow extra room. Considering the average driver is fairly inattentive, I oftentimes wonder if, they actually realize the length or have mirrors adjusted properly to actually see and judge the end of the second trailer......
   / Long vs short bed truck when pulling a gooseneck? #24
For that, you have to do like my brother did with his F550, only he went with 11' plus the over cab part.:laughing:
That's an impressive setup!
   / Long vs short bed truck when pulling a gooseneck? #25
Exactly!
Another thing about short beds is that the fuel tank capacity is usually less than a long bed. My F-250 LB has a 38-gallon tank. As I recall the SB has a 29-gallon tank. Even at 13MPG unloaded, my LB has 117-miles more range than a comparable SB.
If I had my way, I'd like a 10' bed.
Good decision, Long bed will serve you very well.
I changed out my 38 gal tank for a 57 gallon transfer flow tank, and love the extended range.
   / Long vs short bed truck when pulling a gooseneck? #26
Like these? Ford pickup replacement tanks
If I was flush with bucks I'd like to have one. Are they deeper than OEM units? If so I'd be a bit concerned about ground clearance if it was a significant amount.
   / Long vs short bed truck when pulling a gooseneck? #27
That's the one. They do sit around 2" lower than the stock setup. To negate this, I added 2" coil extenders up front, and added an extra spring in the rear pack along with air bags. Went up 2" with no issues. Shopped round a bit and saved a few hundred $$$. Put it in myself with only minor cussing. :laughing:
   / Long vs short bed truck when pulling a gooseneck? #28
I haven't seen that very often, but every once in awhile I'll see one with a boat or a golf cart behind a travel trailer. If it were me, I'd be concerned that a trailer might have a flat and I wouldn't know it.
   / Long vs short bed truck when pulling a gooseneck? #29
I've seen a few around...and always wondered how hard it is to back them up...
   / Long vs short bed truck when pulling a gooseneck? #30
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
LOT: (6) Grease Guns (A59076)
LOT: (6) Grease...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58216)
2014 AMERITRAIL...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
