murphy1244
Super Star Member
- Joined
- Nov 25, 2011
- Messages
- 16,336
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Do not drive with your bucket so high like him. He is asking for it and sooner or later he will flip it.
This is one video that swung my decision to the BX.
Its the definition of Master of None.
Yes it does alright in different jobs but it doesnt excel in any.
Have you ever trenched with a BX? Its too small to drive over the trench when your finished so unless you can drive straight out, your a bit stuck. Its hoe doesnt have enough swing to swing the rear over end over the trench to get out. It also has limited reach, so that means frequent moves, which wouldnt be so bad if it had a creep function you could use from the BH operators station, but it doesnt. Thats just how it is.
Ditching from the side, its "ok" but it suffers from limited reach, which means frequent moves and wasted time. On top of that it has relatively weak hydraulics and its light weight doesnt allow you to maximise what hydraulics are there. Try digging some hard packed red clay like I have around here. Its so light you'll drag your *** all over the place so you need to rely on small bites using the curl. Slow process. And the hydraulics themselves are slow.
Mowing wise, its never been a good mower to me, even with the fine cut deck. My ZD completely blows it out of the water as far as cut quality. Its heavy and all the weight is over the front wheels on the BX which means it compacts the grass and that grass leaves streaks. The ZD is just as heavy, but its weight is in the rear so the grass is cut before being squashed.
Lift capacity on the loader is too low to be overly effective. It can only lift what, 800lbs? It could barely lift my new woodstove out of the truck (and I have my hydraulics "turned up"). It certainly cant move a full pallet of firewood,not even a half pallet.
Right now, im dealing with the lack of 3pt hich lift height and ground clearance. I need a rear blade that will offset and angle to repair my washed out driveway. The BX's lack of lift prevents me from being able to do that with an off the shelf blade so Im going to have to design and build one to work with the BX's limitations. Frustrating.
I know you guys dont like hearing your babies arent perfect. I got one and call it like it really is, warts and all. Im not saying it isnt a tough well built machine, but people need to hear about the flaws too. As a retired homeowner machine, one where you have all day to do something. Or you want to put in some flower beds.. Or you dont want to damage the lawn.. then fine, but you should know that going in.
Scooby, you are funny. For you the glass is half empty. I don't get it. I guess my F350 doesn't excel either because it won't pull a 50 foot reefer like a KW or Peterbuilt. That's fine. Again, it's not designed for commercial excavation, mowing, and lifting. I agree the BX is heavy and mats down grass. I live that, too. I don't have a hoe. I can't comment there. I have lifted 600 pounds plus with no issues. I doubt anyone looking to lift massive weight, or digging many long trenches, would choose a BX. A homeowner looking to have versatility? YES. is that what it's designed for? Yes. I understand you Scoob, but from what you say, a B is a waste, too. It is a master of none, too. Are we all to buy TLB's or large loaders, or three individual pieces of equipment?
Robert, its not that the glass is half empty.. Its a great little machine, but it really has a lot of "issues" that can be frustrating. Everybody screams "buy it", but nobody points out the BX's inherent weaknesses. Potential buyers should hear this.
A BX without a Hoe is a powered wheelbarrow. If you've never used a BX Hoe, you shouldnt be recommending it to others.
In retrospect a B is as small as Id go as far as a tractor is concerned, if youre going to use it as a tractor and frankly an L is even better.
If I had an L, Id have a repaired driveway by now.
