Mace Canute
Elite Member
It's subsidiary is in Canada...it's an international company.
I am a Master Certified Toyota Technician working at a dealer in central NC and am up to my ears in gas pedal recalls. Actually Toyota calls them Service Campaigns - not recalls, that's what the news calls them. There are two different types of gas pedals involved, both are electronic sensors that send a signal to a computer which sends a signal to a motor on the throttle of your engine. If you where to experience a "stuck" pedal, I seriously doubt pulling up on it would help unless it was actually jammed on something. We have been shortening both types of pedals on Camrys and shimming them on all others. There is also an ECM recalibration on the Camry Non-hybrid models. I am told it will cut power to the engine if gas and brake are requested at the same time, but am unsure exactly. My advise to people is drive your car. A very small amount of cars have experienced problems and if you have no signs of abnormal operation, then it will likely not magically start happening now. To be safe, call your local dealer and make an appointment to have the campaign performed. I did try to shut down a smart-key car the other day and it will not turn off in neutral or drive while moving. My advise is shift to neutral and coast to the side of the road. The engine has a rev limiter to keep it from damaging itself, but worst case, let her blow. It's only a car. I am sure Toyota would give you a new one and then some if that actually happened. BTW anyone remember the Explorers in ditches 10 years ago? It's not even that bad! We will survive. Toyota is a GREAT manufacturer and will fix all these vehicles as soon as possible.![]()
Funny Youtube. Not much time to call 911 though. Just a note, I did try driving a Camry today WOT and pressing the brake after the ECM reflash. Car almost immediately slows down but it was hard for me to tell exactly why. At first I was told it would cut fuel, but it did not feel like it to me. Engine RPM was still pulling at car, but it had no torque. The second the brake was released, you were back to normal WOT - no lag. Maybe VVTi severely retarding timing -????? I'm not a designer or exec, I just fix'em when they say fix'em. Another note: CTS and Denso pedals are being shortened, CTS pedals being shimmed, carpet padding being modified, stopper block being installed under pedals, ECM being reflashed, floor mats being secured with clips and unauthorized mats being taken out of vehicles. Which one made the gas pedal stick?![]()
If GM would have done anything close to this, it would have been an international scandal 2 weeks after it was first discovered, not 2 years later.
Remember Ralph Nader?
