I am a Master Certified Toyota Technician working at a dealer in central NC and am up to my ears in gas pedal recalls. Actually Toyota calls them Service Campaigns - not recalls, that's what the news calls them. There are two different types of gas pedals involved, both are electronic sensors that send a signal to a computer which sends a signal to a motor on the throttle of your engine. If you where to experience a "stuck" pedal, I seriously doubt pulling up on it would help unless it was actually jammed on something. We have been shortening both types of pedals on Camrys and shimming them on all others. There is also an ECM recalibration on the Camry Non-hybrid models. I am told it will cut power to the engine if gas and brake are requested at the same time, but am unsure exactly. My advise to people is drive your car. A very small amount of cars have experienced problems and if you have no signs of abnormal operation, then it will likely not magically start happening now. To be safe, call your local dealer and make an appointment to have the campaign performed. I did try to shut down a smart-key car the other day and it will not turn off in neutral or drive while moving. My advise is shift to neutral and coast to the side of the road. The engine has a rev limiter to keep it from damaging itself, but worst case, let her blow. It's only a car. I am sure Toyota would give you a new one and then some if that actually happened. BTW anyone remember the Explorers in ditches 10 years ago? It's not even that bad! We will survive. Toyota is a GREAT manufacturer and will fix all these vehicles as soon as possible.
