LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #261
That's odd .my XR4040C has a prefilter next to the fuel tank on the left side just in front of cab...
   / LS Tractor Oil, Gas, & Air Filter Information #262
Checked LS filter kits the 4100 series doesn't have a prefilter it's a 5 piece filter kit , the 4000 series is a 6 piece filter kit ....wonder if ls upgrade the main fuel filters for the 4100 ....seems a bit odd
   / LS Tractor Oil, Gas, & Air Filter Information #263
arits74 and Kc8ehd are correct.....checked the manual and no pre-fuel filter for the 4145. Seems odd.....I guess you could add an inline pre-fuel filter if you wanted one. I would....adds a little more protection.
   / LS Tractor Oil, Gas, & Air Filter Information #264
Gearing up for my first service on my XR4150H, I believe I got these WIX numbers correct. Question though, the Hyd filter (51715) says it has a 35 micron rating. I thought I had read on here it was a 10 micron or that I needed a 10 micron. Any help would be appreciated - Thanks
   / LS Tractor Oil, Gas, & Air Filter Information #266
I have a 2017 XR4140 cab tractor with a syncro gear transmission. Its time for my 50 hour service and I want to change my hydro filter. My book calls for ISO VG 46/68. My question is what oil are y'all using? I guessing I'll lose a gallon or so. Thanks for the help.
   / LS Tractor Oil, Gas, & Air Filter Information #268
303 universal tractor fluid
   / LS Tractor Oil, Gas, & Air Filter Information #269
Several have posted that they have been successfully using the $7 Fram TG3593A in their G3033 or G3038 CUTs. I am not a Fram fan but, while I don't find a domestic cross for that Fram filter, not even a Fram Ultra, I don't give up easily. So, I checked applications and found that this Fram filter is used widely - including in the 2007 SUBARU OUTBACK 3.0L V6. Running this car through the WIX applications manual, Ta Da, I find that it uses the WIX 51334XP. WIX is a filter I respect, especially because it can be had for $10.
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
1761 (A58375)
1761 (A58375)
50 Foot Loading Dock (A56436)
50 Foot Loading...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
