LUBING FEL
   / LUBING FEL #31
Take a zerk with you so you can match the size and you can probably find them at any auto parts store. No need to buy them from NH.
   / LUBING FEL #32
</font><font color="blue" class="small">( What you normally want in a grease is a lubricant that will not absorb water & has a high temperature rating so it will not break down under stress. Attached is some info I found on the net. )</font>
The lithium grease I use is red in color, rated for extreme pressure and temperature, and is moderately water tolerant. A greatly appreciated bonus is that lithium grease is way less nasty than black grease. I don't even mind getting it on my hands. Well, not too much...
   / LUBING FEL #33
Jim should one expect to find metric threads used on the New Holland zerk fittings?
   / LUBING FEL #34
</font><font color="blue" class="small">( Jim should one expect to find metric threads used on the New Holland zerk fittings? )</font>
I have to say that I'm not sure about the tractor because it's made in Japan, but I think the loader has all SAE measurements as indicated by looking at the parts breakdown in your Owner's Manual. All the hydraulic fittings are in inches. Anyhow, an auto parts store these days should have plenty of both foreign and domestic sized fittings.
Now let me be completely candid.... I'm not sure there is such a thing as metric or SAE sized fittings. If anyone else knows the answer, please speak up because I'm gonna plead ignorance. /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif
I do know that the New Holland parts manual has a lot of different part numbers for "lubrication nipples" as they are called. Of course, the parts manual doesn't list the zerks for the loader. It doesn't have anything for the loader except the joystick and front remotes which are on the tractor. /forums/images/graemlins/confused.gif /forums/images/graemlins/crazy.gif
   / LUBING FEL #35
<font color="blue">( I'm not sure there is such a thing as metric or SAE sized fittings. )</font>
I bought two boxes of assorted grease zerks awhile back; one was labelled SAE and the other labelled metric, so I assume they were labelled properly. /forums/images/graemlins/wink.gif Of course, when I accidentally knocked both boxes off the shelf at the same time, I just gathered them all up in one box. /forums/images/graemlins/frown.gif
And this place claims to have both.
   / LUBING FEL #36
Metric VS SAE fittings refers to the type thread for attaching the fitting. The same grease gun will fit either.
   / LUBING FEL #37
There seem to be coarse-thread Metric zerks and fine-thread Metric.
I bought a sealed baggie of zerks labelled Metric. They will start but they won't screw in past 1/2 turn on my Made-in-Japan Yanmar.
I got out my magnifier glasses and caliper - sure enough, the thread diameter was the same as the existing fittings, but the plugged-up old fittings I took out of my tractor had coarse pitch threads while these new ones were fine thread.
Back to CarQuest to see if they have coarse-thread Metric.
   / LUBING FEL #38
Bird
The fittings on my <font color="orange"> Kubota </font> Tractor are not a thread that I was able to find at an Auto Parts Store. /forums/images/graemlins/frown.gif
I had to buy them at my dealer. /forums/images/graemlins/blush.gif
They are 6 X .8 or .75 mm. /forums/images/graemlins/confused.gif
I'm not sure about the <font color="blue"> NH </font> Zerks. /forums/images/graemlins/tongue.gif
   / LUBING FEL #39
Thanks Bird and others, I also found this link to a place that specializes in lubrication fittings by searching for "grease zerks" on Yahoo.
Fittings & Adapters
I appreciate you guys helping me out here. It just suddenly dawned on me that I have had Japanese vehicles for a long time and always found zerk fittings at autoparts stores, but had not paid enough attention to the sizes. I have several assortments of sizes and I've always been able to find one that would "fit" although now I'm not sure if they fit properly or I was "recalibrating" my threads. /forums/images/graemlins/blush.gif
Just yesterday, I replaced the zerk fitting on my TSC rotary cutter's PTO drive u-joint just in front of the gearbox. It was missing and I went to my assortment and found a perfect 90° match I could screw in with my fingers until it was snug. I looked at the box and it said SAE type fitting.
So when I said you would not have to go to New Holland to get replacements, I should have added that I had never done it and perhaps saying an auto parts store would definitely have replacements might have been a little "wishful thinking." /forums/images/graemlins/smile.gif
   / LUBING FEL #40
Ron, I didn't know there'd be any difference, since I never had to replace one on my Kubotas. And the last zerk I replaced on a riding mower naturally had a pressed in zerk that apparently fell out and got lost. All the assorted zerks I had were threaded, so I just ground the threads down a bit on one and drove it in using an appropriately sized socket, and that worked just fine.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Harley Davidson (A56859)
Harley Davidson...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
