lubricating oils
/ lubricating oils #1
shrekbelly
guys,
i need to start a regular oiling and greasing schedule on my bx. have also got confusing advice on what to use.
what is the concensus on good oils, for my new oiling can/pump. as always, any input is greatly appreciated . . . . to old and broken down, ought to know better . . . hookopotomous regards, shrekbelly
/ lubricating oils #4
gwdixon, steered you right, follow your manual for greasing all points and change your engine oil at least once a year even if your hours are low. I did this on my BX23 TLB and never had a issue. You may want to use synthetics oils if you live in colder areas for the winter, It makes starts a bit easier on engine.
DevilDog
/ lubricating oils #5
For engine oil I have used Rotella, Kubota and New Holland, SUDT for the transmission; lithium base in grease gun. I use mine year round, so I go by hours, but if you don't put enough hours, I would change engine oil yearly anyway unless stored in a heated place. The BX is really simple to service.
/ lubricating oils
sorry i'm such a dreadful communicator, i was/am curious if there's a preferred brand on 3 in 1 lubricant (i have my greases & engine oils lined up).
thanks, shrekbelly
/ lubricating oils #8
I use Breakfree CLP.
/ lubricating oils #9
@TripleR: I used to use a gun oil called CLP that came in jugs and I don't recall a brand name on it....had teflon particles in it. Is that the stuff you use?
/ lubricating oils #11
I got turned on to fluid film by someone in this post,( sorry I don't remember who) to free up my 3pt hitch "eye balls" and I was really impressed with the performance it did amazing things.......until it got cold then it Turns thick and harder to move parts. unless something else happened between plowings, I have to assume it is the cold. It is nice to have a candy smell on you after hooking up 3pt hitch instead of the diesel smell of "PB penetrating oil"...
/ lubricating oils #12
boxers versus briefs. use whatever you are comfortable with, just change it regularly.
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2021 CATERPILLAR 306CR EXCAVATOR (A65053)
2021 CATERPILLAR...
16in. Bucket with Teeth Excavator Attachment (A64194)
16in. Bucket with...
2022 Sany SY35U Mini Excavator (A64553)
2022 Sany SY35U...
2022 EZ-GO ELITE...
2018 International Durastar 4300 Asphalt Pot Hole Patcher Truck (A64556)
2018 International...
