SooperYooper
- Joined
- May 13, 2026
- Messages
- 3
- Tractor
- Mahindra 3540 HST
Mahindra 3540 Hydrostatic. When I press forward or reverse pedal I get a several second delay before the tractor starts moving. I've been banging my head against this for a few days and would appreciate some input.
- Sudden change, not a gradual worsening
- When tractor starts moving, it is not a jerking motion. Its just a slow ramping up. Does not change with RPM.
- No unexpected noises.
- Identical problem in forward and reverse.
- Loader performance is normal.
- Once tractor starts moving, it seem to operate fine under load.
- Changed fluid and filters. Cleaned HST suction strainer. Nothing out of the ordinary noted.
- Checked charge pressure at oil cooler and got ~300psi, which is within spec.
- Backhoe had been on for 6months. Problem started day after taking it off.
Does anyone have a suggestion on what to check next? After ruling out the simple things I expected to see a low charge pressure. Since that pressure is fine, the service documentation suggests this implies damage to the HST itself. I'm really really really hoping I'm missing another possibility.
Any help would be greatly appreciated. Thanks!!
