johneic
- Joined
- Jan 4, 2010
- Messages
- 228
- Location
- Paducah (West) Kentucky
- Tractor
- JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
Hi, this is for a LW7, running a prince 7 gpm pump, fed with 1.25 inch hose, 3/4 inch outlet hose. It was 24 degrees this morning, 34 now, 10:45am, no power when I first started to dig, I let it high idle for about 45 minutes with the pump on, ran it at 1,200 RPM, I then had decent power to dig but it started to foam up and come out the dipstick and fill neck, running 32 weight, Oil is 49 degrees, tractor hydraulics work fine. Any thoughts appreciated. It was the same temperature outside yesterday, hoe dug fine, I did not change anything overnight, tried to dig at idle speed, was jerky almost no power, ran it up to 1,000 RPM. decent power, started foaming out the dipstick again.
