y
Magnetic Oil Drain Plugs? The good/bad/ugly?
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #1
Denwa
Blaine WA
Kubota B20
Hey folks, Anybody out there using magnetic drain plugs for your oils?
This seems pretty common in motorcycles, but at least my B20 does not have them. Neither in transmission or engine.
Any particular reason against using them in a tractor? Experiences?
Can't think of any negatives and lots of positives. In motorcycle tranny use they typically show deposits that are just like metallic dust. Looks fuzzy when attached to the plug, but no discernible texture if removed. Any texture beyond dusty is cause for further investigation.
Any recommends for where to get for our brand?
Regards,
Dennis
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #2
I would rather have the magnetic plug then not. Not only does it help with seeing what's up, it helps keep crude at the bottom of the pan.
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #3
On my Kubota, (I believe it's the oil filter), has a magnet attached to the base. I think a magnet is a good thing. I am not sure how well the filter would do in catching all these small particles. It may also give some idea the shape the engine is in by the amount of black crud on the magnet. Maybe someone that knows more can answer this one better...
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #4
On the M7040HD there is a magnetic attachment on one of the two hydraulic filter connector threads. I always switch out my auto oil drain plugs to magnetic ones, as I can't see how it can do anything but help keep metal particles out of the engine.
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #5
Friend of mine is a gearhead, he buys magnetic drain plugs here
They certainly seem to cover the field. A 22mm plug is $11 and change.
For one plug, considering gas and time, DIY hardly seems worthwhile. However if several plugs are wanted, then it pencils out to take that trip to Radio Shack for the magnets. Besides if one just bought a drill press vice from Harbor Freight (me), then DIY is kind of a point of honor ;' >
Dennis
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #7
I've use magnetic drain plugs on all my equipment but have never gotten around to get a couple for my L39. On my aircraft I have chip warning lights that can give good info or be a pain if it is only reporting fuzz, a natural byproduct of gears meshing. The pain part is compensated for with Fuzz Busters which burns the fuzz with an electrical spark but if the metal in the magnetic plug is a chunk of bearing or gear the warning light will stay on.
Jim
Jim
Now that's some sophisticated fuzz busting! I can appreciate the want of such a system at level 20. Wonder what Kubota's equivalent would run? :'>
Dennis
Single engine land w/ a whopping 450 hrs.
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #9
I think they're a good idea. If you want one, spend 10 minutes with a drill press, then insert a rare earth magnet from Lee Valley, etc. It isn't like it's going to come loose and get into anything.
Chilly
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #10
I have one on my truck (CTD) I don't know if it doe's much good given the make up of internal engine parts but it certainly cant do any harm.
I believe that these are installed by Cummins at the factory.
TGR
Chilly
I will be stopping by Radio Shack ASAP for my rare earth magnet buy.
Thanks y'all for all the input and ideas. Drill press (got it), glue (got it),
magnets (shopping list).
Having mag drain plugs will tell a lot and likely save from a lot of potential
problems by trapping small debris.
Regards,
Dennis
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #12
Denwa-
Sounds like you have all the gear to do the tight press fit plug.
If you decide to go the loose fit & epoxy route you will need to "vent" the hole. One way is to use a syringe to put the expoy mix only at the bottom of the hole so the air can escape around the magnet as you insert it. If you don't get the air our the magnet will keep popping out of the hole.
-Jim
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #13
You can glue it in if you want, but from my past experience with rare earth magnets, you won't have to.. try sticking it in the new hole first, if you can get it back out it may need glue, if not it's there for good.
Mag drain plugs are good for getting fine particles out of suspension, and they'll tell you if you're starting to get rapid wear in the gear train, etc. More of a comparative tool than anything else, if the first two oil changes show minor buildup then on the third trip it shows a lot more debris, something is going on.
Chilly
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #14
I would pot it with epoxy, but not to keep it from falling out. As Chilly correctly states, it won't. I would pot it to keep it from fretting due to minute shifting from all the vibration going on all around it. I know, it sort of a belt and suspenders thing, but I'd pot it.
My reasoning: If the fit is loose by .0005" and it sticks to the cylindrical surface of the hole, then it will have only line contact (underconstrained). It's center of mass will be a proportionately large distance from the line of contact with very little preventing it from revolving around the hole in an eccentric path. If it sticks to the cone from the drill point, then it will be making circular line contact (better), but still with it's center of mass removed from the contact, so still underconstrained. It will want to tip and make contact with the cylindrical bore surface. Then it will have 2 point contact - even less constrained. Potting will overconstrain it like a telephone pole in the dirt.
This is why my wife never asks me to do anything around the house [8^).
-Jim
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #15
And you are saying that the magnet will wear out ???? Perhaps the oil around the magnet will lubricate it enough to prevent it from wearing out in my lifetime.
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #16
No argument from me about that.
I'm just compulsive about addressing the "perhapses" of anything I design. In my day job I design bearing compartments for aircraft engines, and I don't like fretting. Fretting is bad - I have seen the results.
I'm also not really familiar with the mechanical and physical properties of rare earth magnets. What happens to one if you slowly erode it into wear particles? Are the particles oxides? Will they be ferromagnetic & remain stuck to, or will they separate from the magnet an go wherever? Will they be abrasive? Do I want them circulating around in my engine or gearbox?
I know - it's just a tractor, not an airliner or fighter jet, but I would beat myself up thinking about that, late at night, so I use the epoxy and sleep well. Somehow, my wife puts up with this nonsense.
-Jim
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #17
-Jim
I fully understand you Jim, My "What Ifs?" have kept me alive in many an emergency!!
Jim
-Jim
Well gents, I went to Radio Shack today to procure some rare earth magnets. Lo and behold, Radio Shack has only one size and type available. It's a tad smaller than a 81mg low dose aspirin, and about the same shape only with sharp edges. I checked on line when I got home, and the web site shows the same. Launch Google....
These are the size and shape that look appropriate for the job.
Rod Magnets
This a quite educational site on the "rare earth" subject.
Rare-earth magnet - Wikipedia, the free encyclopedia
Jim,
And, these two pages will likely answer most of your unknowns, Though I certainly don't know how to drive all those charts. If you can deduce anything useful and interpret it for us non engineering types that would be appreciated.
Technical Specifications
Rod Magnet Pull Force Calculator
Jim, your concern with the fretting things is of course well founded in
experience and professional intuition. And, I would say very correct by what the Wiki info has to offer.
Logic would dictate that if particles of the fragile magnet were to get loose in the oil they would likely stick to the closest ferrous object, likely the plug itself. But if they DID go adrift they COULD end up in the gears, or bearings which would not be good. The transmission case on my B20 is aluminum, so if the particles weren't attracted to drain plug or a shaft, then
life could be less good on the farm. Epoxy, definitely epoxy.....
Thanks for the thoughts,
Dennis
Here's another link for rod magnets, right from the TBN page...
Has great size comparative photos.
K&J Magnetics - Products
Dennis
   / Magnetic Oil Drain Plugs? The good/bad/ugly? #20
I've always thought that magnetic plugs are somewhat of a waste . In My 22 years of working on acft , every mag plug that read continuity ( fouled ) was just pulled and then wiped off by the engine techs . If You are truly concerned about the metal floating around in the sump ,do a UAO . It'll give You a better idea of what's going on in Your machine .
2010 CATERPILLAR 303.5C CR EXCAVATOR (A60429)
2010 CATERPILLAR...
2022 JOHN DEERE 744L WHEEL LOADER (A60429)
2022 JOHN DEERE...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
UNUSED IRANCH MINI HYD AUGER SET (A60432)
UNUSED IRANCH MINI...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
