Mahindra 1526 box blade maximum size
   / Mahindra 1526 box blade maximum size #1
uglychicken2005
Russell, Pennsylvania
Mahindra 1526
A question for those of you with 1526 experience. Being the width of the 1526 is 63", I would like to get a box blade that extends past my tires. Would it handle a 6' box blade full or should I go with the 5'?
   / Mahindra 1526 box blade maximum size #2
Don’t get the 5’- yikes! That would drive you nuts! And too wide you end up limiting yourself in tight areas- plus you run out of HP if pulling hard. I’d get something in the 66-72” range.
If you can swing it, I’d look into a hydraulic top and tilt kit. I have a Gearmore kit but the fit-rite is highly rated- he is on TBN. He was backlogged a few few months but needed full payment up front......
Anyway, T&T is a near must have if you plan to do a lot of grading- dirt driveway, snow removal etc.
   / Mahindra 1526 box blade maximum size #3
This 65" roll over box blade (ROBB) is what I consider to be the perfect box blade for your tractor. Good width, good weight, good versatility. :thumbsup:
That ROBB looks like an intriguing piece of equipment! I would expect it to be a little out of my budget though. It seems to me the cost of a typical bb has increased considerably within the last few years. A bb that was $500 is now around $700+. Anyway, I do have a top and tilt that I fabricated last summer and seems to work pretty well so I might have to go with a 6' unless I can find a 66".
   / Mahindra 1526 box blade maximum size #5
If you are looking to spend less than 1K, then yes you will need to get a 6 footer. Try to get as heavy a unit as you can afford. Weight is your friend when it comes to grading. ;)
   / Mahindra 1526 box blade maximum size #6
I have a 5 ft box for my 1626 which I got a good deal on and that's what's going behind mine, which is 63 inches wide as well. I'll live with it being short an inch and a half on both sides. I think the over flow from the box will cover the tire tracks and if it doesnt I'm not too worried about it just using it mainly for gravel driveway maintenance.
   / Mahindra 1526 box blade maximum size #7
I am pulling a 72" Woods box blade with the Mahindra 1526 HST. No problem in the low / medium range.
   / Mahindra 1526 box blade maximum size #8
I would prefer a 72 but I already have the 60 and its brand new so that's what has to go on it for now. Thanks for the info though.
2018 HINO 268 24FT NON CDL REEFER BOX TRUCK (A59575)
2018 HINO 268 24FT...
NEW Woods 6ft Finish Mower (A56436)
NEW Woods 6ft...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2000 INTERNATIONAL 4900 CAR HAULER (A59575)
2000 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 Subaru Outback AWD SUV (A59231)
2001 Subaru...
