mahindra 2015 vs kubota 2230 & massey gc2300
   / mahindra 2015 vs kubota 2230 & massey gc2300 #21
<font color="green"> Yet because of the wider tires your turf PSI will actually be less than the 2230 </font>
I don't know that the statement is true, but if it is, the Mahindra weighs more and provides less traction because the PSI of the tires is lower. And if the PSI is lower due to the wider tires, then physics dictates that even with more surface area on the tires it has to have less traction. Then what advantage does the extra weight provide? None.
And since it offers less PTO hp than the little BX, it would also be the inferior mowing machine in terms of providing power to the deck when the lawn gets a little too tall. Given similar size mower decks, the tractor with more HP will simply perform better.
And since the frame of the 2015 is a bit larger, it will not turn as well around the landscaping so that means it will take longer to mow with.
I guess there is a reason that the BX and the B series Kubotas are far and away the most popular mowing tractors in the US. I can't say what will cost more or less, but I suppose if the 2015 costs less then it proves you get less even if it weighs more.
   / mahindra 2015 vs kubota 2230 & massey gc2300 #22
</font><font color="blue" class="small">( the Mahindra weighs more and provides less traction because the PSI of the tires is lower. And if the PSI is lower due to the wider tires, then physics dictates that even with more surface area on the tires it has to have less traction.)</font>
You might want to think about that a little more. More weight + larger surface area of tire in contact with ground = less PSI (because the tractor's weight is spread over a larger area) and more traction. At least theoretically, this should result in better traction and less damage to turf.
Later,
BR
thanks.....im not afraid of indian i already have a 4500 2wd, plus the compairable john deere was made 100 miles from where it was made in india, there both good machines.
   / mahindra 2015 vs kubota 2230 & massey gc2300 #24
I believe India has the largest tractor market in the world and manufactures more tractors than anywhere else. I'd say they must be doing something right.
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2015 Dodge Grand Caravan (A47477)
2015 Dodge Grand...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A55745)
MCELROY 500 SERIES...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2018 Nissan Sentra Sedan (A55758)
2018 Nissan Sentra...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
