Mahindra 5145 Hydraulic Fluid Return Port
   / Mahindra 5145 Hydraulic Fluid Return Port #1
confederatemule
I am mounting an auxiliary, two spool, control valve on my Mahindra 5145. It is an open center system. I have to run a hose from the "t" port on the auxiliary valve to the fluid reservoir, which is the transmission/differential housing, on the tractor. I have looked more than once and can not find a plug or anything similar to connect to.
Can anyone tell me where I can attach the hose to the transmission/differential housing to return the fluid on the 5145 Mahindra?
Thanks fer any help.
   / Mahindra 5145 Hydraulic Fluid Return Port #2
Can you follow the Tank line of the loader valve and Tee the new line to that line? Might be another option.
This is the only plug I can find. I am pretty sure it opens into the differential housing.
   / Mahindra 5145 Hydraulic Fluid Return Port #5
That could be it indeed. Accordingly to the parts catalog, it's just a plug (#15) and not some sort of valve. Looks like the threads are M22x1.5.
Well, as it turned out, I was called away from my tractor today. Maybe tomorrow.
As I said I was pulled away. I am back now. PTSG, I have taken the plug out. Now I have to find a fitting that will screw into that hole and seal with an 'O' ring. I would like to have a JIC male fitting that will screw in.
   / Mahindra 5145 Hydraulic Fluid Return Port #9
Here is a male 1/2" JIC to male M22x1.5 adapter, no seal so you would need an o-ring or a dowty washer. 9067-08-22 | 1/2" JIC Male x M22x1.5 Metric Male
And the same fitting but with a built in seal on the metric side, also slightly cheaper: 9068-08-22 | 1/2" JIC Male x M22x1.5 Metric Male w/ seal
You may want to still pull out the plug and measure the OD to make sure it's M22x1.5, because the parts catalog could be incorrect.
Thanks for the links. I will take it out tomorrow and do my best to measure it.
It is M22 x 1.5 threads. The local hydraulic company could order what I wanted. I wanted it to be M22 x 1.5 to JIC male at a 45 degree angle. He said it would have to be two pieces in order for me to be able to have the hose end in the direction I needed and nothing leak.
Not pertaining to fluid return, but hydraulic system related. Is the hydraulic system on a Mahindra 5145 an open loop system?
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
