Mahindra 5145 Hydraulic Fluid Return Port
   / Mahindra 5145 Hydraulic Fluid Return Port #1
confederatemule
I am mounting an auxiliary, two spool, control valve on my Mahindra 5145. It is an open center system. I have to run a hose from the "t" port on the auxiliary valve to the fluid reservoir, which is the transmission/differential housing, on the tractor. I have looked more than once and can not find a plug or anything similar to connect to.
Can anyone tell me where I can attach the hose to the transmission/differential housing to return the fluid on the 5145 Mahindra?
Thanks fer any help.
   / Mahindra 5145 Hydraulic Fluid Return Port #2
Can you follow the Tank line of the loader valve and Tee the new line to that line? Might be another option.
This is the only plug I can find. I am pretty sure it opens into the differential housing.
   / Mahindra 5145 Hydraulic Fluid Return Port #5
That could be it indeed. Accordingly to the parts catalog, it's just a plug (#15) and not some sort of valve. Looks like the threads are M22x1.5.
Well, as it turned out, I was called away from my tractor today. Maybe tomorrow.
As I said I was pulled away. I am back now. PTSG, I have taken the plug out. Now I have to find a fitting that will screw into that hole and seal with an 'O' ring. I would like to have a JIC male fitting that will screw in.
   / Mahindra 5145 Hydraulic Fluid Return Port #9
Here is a male 1/2" JIC to male M22x1.5 adapter, no seal so you would need an o-ring or a dowty washer. 9067-08-22 | 1/2" JIC Male x M22x1.5 Metric Male
And the same fitting but with a built in seal on the metric side, also slightly cheaper: 9068-08-22 | 1/2" JIC Male x M22x1.5 Metric Male w/ seal
You may want to still pull out the plug and measure the OD to make sure it's M22x1.5, because the parts catalog could be incorrect.
Thanks for the links. I will take it out tomorrow and do my best to measure it.
200 Gallon Tank (A57148)
200 Gallon Tank...
Hustler super Z zero turn (A56859)
Hustler super Z...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2003 Big Tex 10PI...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
