Mahindra emax 25 Hydrostatic Transmission Fluid
   / Mahindra emax 25 Hydrostatic Transmission Fluid #1
Matt2796
Mahindra Emax 25
Wondering if I can use Castrol UTF in my hydrostatic transmission for the transmission / hydraulics in my Emax 25? Manual says to use API GL-4 grade, 80w gear oil. Can't find these specs with the castrol.
Thanks!
   / Mahindra emax 25 Hydrostatic Transmission Fluid #2
I would stick with the fluid provided by Mahindra.
80 weight sounds like a misprint in the manual. Technical writers get things wrong sometimes, and it can cause problems if it is not correct.
As the highest weight hydraulic oil I am aware off is equivalent to 30 weight.
They don't sell it at the dealer. I'm wondering if this would be a replacement?
   / Mahindra emax 25 Hydrostatic Transmission Fluid #4
Gear oil SAE grades are not similar to motor oil grades. For example the Castrol UTF, Shell Rotella HD and Delvac Hydraulic fluids are GL-4 fluids rated at @80W to 85W grades but in motor oil equivalent terms these are multigrade @10W-30 rated oils. There are cautions regarding usage for these UTF's; for example, these are not supposed to be used in hypoid gear applications.
In summary, I believe the Castrol UTF will be suitable for the OP's Mahindra based on requirement stated in the original post. So will the Shell, Delvac and Chevron 1000 THF fluids. Separately, there are low viscosity fluids in use by various manufacturers. I recommend speaking with Mahindra Tech Support to determine whether the factory fill was low viscosity. If so, you could source a low viscosity fluid such as Hygard low viscosity. Some leads anyway.
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
(4) ALUMINUM RIMS FOR KAWASAKI MULE (A58374)
(4) ALUMINUM RIMS...
1999 CLEMENT END DUMP (A58214)
1999 CLEMENT END...
