Mahindra emax 25 vs Kubota BX2670
   / Mahindra emax 25 vs Kubota BX2670 #1
mcgoo
Bronze Member
Barrie
Cat 301.8C
Hello, trying to decide between a Kubota BX2670 and a Mahindra emax 25. I have 2 acres basically all lawn, relatively flat with quite a few trees. I have a large driveway but have a friend clear snow with a larger tractor. I am getting quotes with mmm, fel, the kubota is being quoted with a quick connect and forks. I have to move a bins and light material outside periodically. I also plan on starting a small garden and adding a rototiller in the spring. They are coming in at the same price but the forks are a $1600 option. I currently have a Kubota GR2100 and like it for cutting grass but need something with a loader. I would like the extra lift capacity of the Mahindra tho. Before someone suggests going to two machines I am not interested. I have access to larger machines of all sorts and own a mini ex and a forklift.
   / Mahindra emax 25 vs Kubota BX2670 #2
Because you neglected to paragraph, your post is unclear.
Is your plan to buy a tractor with a MMM, then eliminate the Kubota GR2100?
Clarify what information you want on forks. There are several types/forms of quick connects, proprietary to individual brands.
Are you referring to SSQA forks and attachments? SSQA is a manufacturer's standard, with the same specs, in various sizes, for all brands.
Yes I am going to sell the GR. I need forks for sure. When you factor this in the Mahindra is about 3k more if I we to get a quick connect setup aftermarket with forks.
   / Mahindra emax 25 vs Kubota BX2670 #4
The Kubota has been quoted with there system I would think I would get a skid steer universal for the Mahindra.
   / Mahindra emax 25 vs Kubota BX2670 #6
SSQA is far better than any of the pin-on quick attaches. However Kubota has several different quick attaches.
Get a Kubota quote with SSQA so you have an apples-to-apples comparison.
The advantage of SSQA is three things: 1. FEL load is closer to the tractor, so lift capacity is increased. 2. Loader bucket weight is not part of every lift, subtracting lift capacity. 3. Any brand SSQA attachment will fit. (Brand specific quick attaches usually take only that brand's attachments.)
With SSQA Kubota lift may equal or surpass Mahindra lift capacity.
Clear??
Anything else?
Kubota bx will have the skid steer qc in the new year but not at the dealership yet. Thanks for the advice. Does it make sense that the Mahindra is more than the Kubota tho?
   / Mahindra emax 25 vs Kubota BX2670 #8
If the Mahindra has SSQA and the Kubota does not have SSQA, YES.
Don't rely too much into manufacturer's specs. No one certifies nor audits specs manufacturers publish. Plus or minus 10% is essentially equal, in my opinion. Some portion of wannabe specs is "dare".
The quote is the same without forks or ssqa
So the Mahindra is more by 3k by the time I add th ssqa
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
TITAN - SET OF 18.4R46 NEW AG TIRES (A52748)
TITAN - SET OF...
Homemade Flatbed T/A Tilt Trailer (A50323)
Homemade Flatbed...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2012 Ford F-450...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
