Mahindra Max 26XL HST - A New Owner's Journal
   / Mahindra Max 26XL HST - A New Owner's Journal
using gasoline to start or enhance a burning fire is setting yourself up for serious injury, or death.. My Nephew did that, and I yelled at him for a long time.. I, Myself, had My hands on fire from gasoline that leaked out of a gasoline torch on which the adjustment knob came out of the torch.. pain, 3rd degree burns, treatment at a hospital is just not worth it.. btw, gasoline can explode when used on fires..
That sounds awful. :eek: Burns are the worst; so painful.
Actually I almost always start bonfires the same way you'd light a campfire, with no accelerants. But had to get rid of this bad gas.....
When STARTING the bonfire I toss a burning stick (a pine knob works pretty good) onto the edge and run. Using gas to "enhance" a fire is the most risky.
The yahoos who used to do yard work for me couldn't start or keep a fire going without gallons of gas before and during, and sometimes not even then..... then they'd get to whooping and hollering and seeing who could get the biggest explosions. :confused:
Don't know what a gasoline torch is but sounds scary.
Good lesson learned!
As a new tractor owner I try to be very mindful of how dangerous things can get. And it is easy to get over confident.
Glad that no one got hurt....or worse.
BTW, I enjoy reading your Journal. You are doing great!
Thanks, Shooterdon. I was hoping other new tractor owners would relate to my chronicle of mishaps and small victories.
Thank goodness for TBN, right? Reading everyone's stories for a couple years, the proper precautions got burned into my brain pretty well. Yet, you rarely hear of a new tractor owner getting killed; seems like it's more often an older farmer. Maybe God watches over children and fools....and new tractor owners. :)
   / Mahindra Max 26XL HST - A New Owner's Journal #63
look here. Zangobob's Blowtorch Heaven - The Horror Stories of Torching
   / Mahindra Max 26XL HST - A New Owner's Journal #64
Good story:
Years ago my friends neighbor whom I've met decides he is going to have a big bonfire for everyone in his neighbor, Kids, friends etc.
Typical suburban professional, had money lots of toys, did not seem like a yahoo.
He uses gas. Lots of gas, I guess.
Vapors build up and the whole thing explodes. He get tossed into a tree, Broke wrist and leg.
In the hospital, all busted & burned up, he had to endure the wrath of his wife for putting everyone in such danger, especially children.
Plus:
The lawsuit could have destroyed them.
Yeah stupid me I've used gas too, even after hearing about the above, with a lot of respect. I use diesel, and old tires on pallets, scrap wood mostly to get a burn pile going.
Once the stumps start to burn, they go for days.
Week 6 (con't): My brother gets religion
So today he wanted to continue grading on the road where he almost tipped yesterday. I was watching from afar and I have to say he apparently "got religion" after that scare. He was going way slower and constantly keeping both FEL and BB as low as possible without me nagging him. :) He also decided on his own to stop doing the 14-point turnaround in the middle of the downhill. "Turning around there is just too risky. Besides, it's just as quick to go all the way to the bottom and turn around," he said. True.
I feel a lot better about him operating the tractor now.
   / Mahindra Max 26XL HST - A New Owner's Journal #66
I discovered I couldn't raise the blade high enough when tilted to get more than an inch of clearance when traveling. Turns out the arms that come down to support the lower links have two holes, and it was set in the lower ones. So pulled the pins out and used the higher holes, gaining me almost 2" in height. Also, finally worked the adjustable side-link loose, greased it up, and now it works like a charm.
The arms are Lifting Rods, with screw adjustment on the right. The pin holes are in the Lifting Rod stirrups.
You can use the upper hole on the right side and lower hole on left side to put "some" tilt in your blade without stressing Lifting Rod adjustment thread. Heavier tractors have four, possibly five Lifting Rod stirrup holes.
If you acquire a one row garden cultivator or a tool bar implement the Three Point Hitch usually needs to be in the Lifting Rod stirrup lower holes in order to get satisfactory ground penetration. The upper holes are the "normal" pin setting on compact tractors.
Thank you for giving me the proper names. What a great idea, if I need just a little tilt, to put one side in the higher stirrup hole; way less work than adjusting the side link screw. That would be a small tilt but might come in handy. Interesting to know the upper holes are the normal setting, as mine were in the lower holes. I find I generally need more ground clearance with my implements (partly due to the uneven ground) but I can see if you're pulling plowing-type implements the lowers would be better.
   / Mahindra Max 26XL HST - A New Owner's Journal #68
Nice thread. Did you consider any other brands before going with the Max26xl???
Going through the research process now to get our first "big" tractor, but out of the gate I felt that the Max was a great choice.
Glad you found my thread of interest. I really hoped other tractor newbies would appreciate an honest account of first-time tractor ownership. :)
I did look at other brands (my first thread was Using a Tractor on Mountain Property and I considered a lot of options there). I had zero brand loyalty going in.
Since I do live in the mountains, the ability to safely operate on steeper slopes was probably my first priority, and Mahindra was one of the tractors that is inherently a tad better at that IMO (more built-in weight, wider stance, larger tires, etc). I also am not mechanical, so needed a good dealer nearby, and preferred a relatively simple tractor with fewer electronic doo-dads, without DPR or other regen stuff I had to worry about. Didn't need or want to pay for some of the fancier options and refinements available on other brands. All of this made the Max a good fit for me. Someone with different priorities and needs will prefer a different brand.
People will argue their tractor is just fine on slopes (maybe, but have you seen mine?); that the electronic doo-dads are reliable and well worth the cost (but I like that I can understand everything I'm looking at. I can look under the tractor and in two seconds understand how things work). Yes, a Kubota FEL has a cushion valve that makes operation smoother (but with a little practice, mine is smooth enough for me). They will say DPR really isn't a big deal (but for me it was just "one more thing" I had to deal with in a process that was already overwhelming). And the price was fantastic. In short, I wanted what I wanted, and I got a tractor that suits my particular needs and preferences. Yes, there are objective differences between the tractors but in the end, the choice is subjective. So define your priorities, listen to advice (but beware of brand loyalties--and prejudices), and choose what suits YOU.
It's been a fun process, and having a tractor has been life-changing. If you're a "do-er" like me, you can do SO MUCH MORE (with so much less backache). :) Couple months in, I wouldn't change a thing.
Welcome to TBN, and good luck!
Re: Mahindra Max 26XL HST - A New Owner's Journal FEL work
Week 7. Needing an Adjustment
Seems the tractor needs a couple of adjustments. It has begun to creep a bit even when the HST pedal is released. Plus, the parking brake has become difficult to set, and sometimes pops back out. The combination could of course become dangerous. For now, I lower both FEL and rear implement every time I get off the tractor, just to make sure it doesn't move. These are no doubt simple adjustments but if you've been following this thread you know that I'm not mechanical (trying to learn). So the tractor will be picked up on Tuesday and returned on Thursday.
This tractor is so simple mechanically, I can actually see what needs to be done, but given my lack of experience and the importance of this working exactly right, am opting for the dealer to do the adjustment.
Besides, it's now time for my 50-hour service! Hooray!
Hmmm, 50 hours in, let's say, 8 weeks. I think that would result in 300 hours per year, although it may be less during winter. OTOH I do a lot of woods-work in winter. If I had my way, it would be at least 2 hours per day. :) Always happy on the tractor.
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A56858)
2007 Oshkosh...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
Cattle Squeeze Chute (A57149)
Cattle Squeeze...
240156 (A56859)
240156 (A56859)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2007 Toro ProCore 648 Walk-Behind Turf Aerator (A56857)
2007 Toro ProCore...
