Massey Ferguson 1635 hydraulic problem
   / Massey Ferguson 1635 hydraulic problem #1
Baileebrett2
Cherryville,Nc
Massey Ferguson 1643
Seems to be a hydraulic problem on my 1643 MF…….When I put the tractor under load either pulling a slight hill bush hogging or pulling another implement in the field the tractor stops moving forward. I can shift into snail range (1st gear) and the tractor will move slowly. I have a power shuttle
   / Massey Ferguson 1635 hydraulic problem #2
Seems there are a few different transmission options for that model, but the parts list doesn't show any drive plates other than a single dry clutch option to power the transmission input on any of them. Are you sure you don't have a dry clutch ahead of the power shuttle and the that clutch isn't slipping and causing your issue?
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
2013 Infiniti M37 Sedan (A55758)
2013 Infiniti M37...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
SHOP STAND WITH CONTENTS (A55745)
SHOP STAND WITH...
