Max 28 tool box
   / Max 28 tool box #21
This is a MAX 25? Where did you get the retractable seat-belt setup? Mine is constantly getting lost under the seat. -J
My Max 28 I had and the 25 I looked at buying originally both had the retractable seat belts.
   / Max 28 tool box #22
-J
Great question do tell; I was wondering that same thing. I added a lanyard to the buckle-end of the seat belt and secured it to the PTO lever; I kept the lanyard long-enough to allow the buckle to fit snugly. I reach for the lanyard at the PTO now. On the other end, I drape the belt over the arm rest or set it in the R/S cup holder.
   / Max 28 tool box #23
This is a solid idea as well. No arm rests for me, but the lanyard is a great idea. I'll be honest and say I'd wear my seat belt more often if i didn't have to fumble with finding it.
And TBT... what is the cup holder you speak of? I didn't think Mahindra knew what they were.....
-J
   / Max 28 tool box #24
   / Max 28 tool box #26
Not sure about the 28, but the only cup holder on my 25 is between my legs.
-J
A couple white pine 1X4s (on end & side by side) easily slides under the seat (with minor milling) and stays-put, to form a rectangle protrusion which can be shaped into a cup-holder or small center console using 90 degree 1X4s and screws.
A 13" L assembly should protrude forward and out 4" while not interfering with operator functions.
When/if I get my tractor back, I will take and post the pics; and spend less time on the internet.....
   / Max 28 tool box #27
I'd be interested in seeing what you cooked up. I've been looking at different clamp on style options for a while now. Best I've found so far is at Duluth Trading Co. They call it the robocup. Looks pretty sweet.... Link below.
Cupholders - Robocup - Duluth Trading
-J
   / Max 28 tool box #28
-J
It is standard i beleive because on the turning seat for backhoe i got with it
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
Case Titan 3530 (A56435)
Case Titan 3530...
