McCormick W4 won't run
   / McCormick W4 won't run
That's right. The engine was overhauled about 3 years before it was parked in the mid 70s.
   / McCormick W4 won't run #42
have you tried acetone ad MEK?
one of the on-the-shelf fuel addatives in a can have it in there.. b12 maybee?
   / McCormick W4 won't run #43
Ya it is black beauty sand. Do you think that might work? If not what do you think will? I'd rather avoid using a tumbler to avoid chipping the valves.
If you turn the pressure down on the compressor and stay back you should be able to blast them. I've never done it. Maybe DJ54 can give some more info on doing this. I'm all ears.
Ya I would love to hear more about it. I've never heard of sandblasting valves before.
   / McCormick W4 won't run #45
i might try rubbing compound and a sponge disc....
   / McCormick W4 won't run #47
yup.. that too!
That's something I never thought of. That might work.
Keep thinking. Maybe a piece of denim might work on the easier stuff.
All of the easy stuff is gone. I tryed a flathead screwdriver to scrape off the carbon on the faces but that didn't even work.
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 4520 (A60462)
John Deere 4520...
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
