Metal deck railing panel DIY ideas
   / Metal deck railing panel DIY ideas
All very cool stuff guys. Tomorrow is a trip into town to see if anything clicks.
   / Metal deck railing panel DIY ideas #12
Really neat railing Eddie. How are the railings mounted to the un-even surfaces of the posts? What is the finish on the railings?
Thanks,
Joe
Thank you.
I use a 4.5 inch grinder with a flapper disk to cut out a flat section of the logs with a wood chisel and then check it with a level. Each panel was built to the size of the opening, so they are all just a little different in size. Between the grinder and the chisel, I can get it pretty close. Then I use 3 Ledger Lock structural lab bolts to attach it to each side. I think they are in the 8 inch range, but I could be off a little on that. I know they are longer then 5 inches, but forget exactly how long.
   / Metal deck railing panel DIY ideas #13
Eddie,
I've always liked your pagoda/gazeebo... or whatever you call it. Its exactly what I'd like to build for my Mom.
Can you post more pics and give any construction recommendations?
Won't be building the fandy roof, but everything else looks great.
Thank you. I posted pics of the gazebo build on my thread about building my pond, Lake Marabou, that was called Creating a Lake. I probably should have stared a separate thread on it, but if you want to glance through all the pics, go to this link http://www.tractorbynet.com/forums/projects/52101-creating-lake-106.html?highlight=marabou and start on post #2119
Case 950 8 Row Air Planter (A55302)
Case 950 8 Row Air...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
2015 ford Fusion Hybrid Sedan (A55758)
2015 ford Fusion...
John Deere 6410 Tractor with Long Arm Mower (A54865)
John Deere 6410...
Eagle Weathervane (A55758)
Eagle Weathervane...
