Yes I do believe this tractor ought to be considered a dedicated light weight tractor on the farm. To put 3-4 bales of hay in the bucket to take to a handful of calves? To scoop manure out of a barn (can't get into with big tractor)? Pull steel fence post? Dig a trench about 3 ft deep to fix a broken water line? Pull a 5 ft brush hog? ( 4 ft won't clear wheels and tractor can't handle a 5 ft in heavy conditions) big tractor is cumbersome up around barns. Back drag gravel and dirt? Yes,on the farm tractor is used a lot and did not hold up. In town tractor does not see the usage near as much. I do not think calling on this tractor regularly and routinely on a near daily basis is asking to much from the tractor or loader.I think you're being a tad bit unreasonable... To say "this tractor belongs in the city and not on the farm" suggests that you think a small, 2500 lb tractor with a loader only rated at 960 lbs, should be considered a dedicated farm tractor. I mean, what would you expect in a loader that small? If you put a heavy duty bucket that weighs 500 lbs on it, you've just cut your lift capacity in half. Shoot, i have a spare 66" heavy duty SkidSteer bucket I'll sell to you for $500 if you're interested. But as soon as you try to lift a load of dirt, you won't be able to get it up.
Point is, a thinner, lighter duty bucket is appropriate for that light duty compact Tractor. It's like buying a Ford Ranger and then expecting it to handle pulling 14000 pounds all the time... Instead of just buying an F350 to begin with. It's not Fords fault if you stress the Rangers frame while asking if to perform like an F350.
I think you're missing the point.Yes I do believe this tractor ought to be considered a dedicated light weight tractor on the farm. To put 3-4 bales of hay in the bucket to take to a handful of calves? To scoop manure out of a barn (can't get into with big tractor)? Pull steel fence post? Dig a trench about 3 ft deep to fix a broken water line? Pull a 5 ft brush hog? ( 4 ft won't clear wheels and tractor can't handle a 5 ft in heavy conditions) big tractor is cumbersome up around barns. Back drag gravel and dirt? Yes,on the farm tractor is used a lot and did not hold up. In town tractor does not see the usage near as much. I do not think calling on this tractor regularly and routinely on a near daily basis is asking to much from the tractor or loader.
Them farm king loaders are kind of an add on I think, i know a guy that has one on a white and a couple guys have them on case- ih tractors. If it is the loader I think it is and the one these guys have, they like them. My telephone is slower than yesterday's newspaper so haven't got that link to come up yet. Was duetz mixed up with allis once? Is this the same outfit that makes duetz-Allison transmission. My dad has that transmission in his pickup, and I've never seen a transmission pull and take so much. Automatic transmission don't have a good track record pulling trailer, but the are getting better. Any way I will try to get this tractor link to come up.
I disagree. Looks like years of environmental conditions eating away at the thinned (from usage) exposed metal. I'm not sure what smoking gun you're seeing from those pics that would indicate "missing metal" ... From any other source than time and use.http://www.tractorbynet.com/forums/...tigue-stress-crack-1520-a-20170915_105645-jpg
If this is the metal the bucket was made from there is a lot of metal missing that was not caused by wear!
Seems there is excessive rusting that appears to follow patterns in the base stock.
