Metal found in yard
   / Metal found in yard #11
A spatula /forums/images/graemlins/confused.gif
   / Metal found in yard #12
isnt that a pin used in setting concrete forms?
Well now, Mith, that's a pretty good list of possibilities you have there. I especially like:
</font><font color="blue" class="small">( A tool for forcing into small openings to see how far it will go in before it gets stuck )</font>
and since I have a variety of tools designed for this purpose, I woundn't be at all suprised if you were right, but it's the hole and the slot that have me wondering. If your suposition is correct, then these details must be used in some way for extraction. This of course implies that I have only part of a set -- the rest of the set being the tools used to engage the slot and hole for removal of said thingy from previously discussed small opening.
Cliff
   / Metal found in yard #14
bky
I think you are the closest of any of the 'guesses' so far. /forums/images/graemlins/wink.gif
   / Metal found in yard #15
Thanks Cliff, I was looking for that. I musta dropped it last time I was over picking up shavings.
Dave
   / Metal found in yard #16
BKY was right
check out this link - see page 5
It's called a wedge bolt and used for attaching handset concrete forms together
web page
   / Metal found in yard #17
Looks to me like the tool to remove a Morse Tapered bit. It takes a wedge type tool to remove a Morse type bit. The hole in it is to keep it handy to the milling machine (or drill press).
That's my best answer. /forums/images/graemlins/shocked.gif
   / Metal found in yard #18
We called 'em snap ties.........used for joining metal concrete form sections together, does your house have poured concrete walls anywhere ?? You drive the wedges in & back out with a hammer............it's real easy to lose a few that way on every job..........
OK, your guys got it. I looked at the PDF and it sure fits the drawing of the concrete form thingy to a tee.
I'll be making more dirt tomorrow, maybe I'll find something else. This turned out to be quite educational.
(I still like Mith's answer though.)
Cliff
So Dave, did you want me to mail it to you then? (COD of course)
Cliff
44029 (A51692)
44029 (A51692)
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
500LB Livestock Galvanized Creep Feeder (A55218)
500LB Livestock...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
