metal piece came out of oil pan when changing oil
   / metal piece came out of oil pan when changing oil
thats what I think .I wont use that stuff .The tractor originally would increase rpm before I parked it .the tapping noise could have been the balls . the tapping wasn't audible at low rpm.Im no mechanic but I,ll attempt to do a basic restore on this . REAR MAIN SEAL IS GONE . Cleaned out the hole under the clutch assembly and 1 quart of oil drained out. first Ill fix the front end and clean up the engine.
   / metal piece came out of oil pan when changing oil #62
might want to get a sneaky pete if it's a 2 piece seal with wedges...
   / metal piece came out of oil pan when changing oil #63
I just love taking something apart.. especially something delicate or expensive/difficult, and seeing rtv extruded out the sides of the case cover.. :)
I never use silicone on anything because it makes a mess and is prone to early failure, especially if you don't clean and prepare the gasket mating surfaces properly. Personally, I've always used Permatex #2 (non-silicone) with great success, but you have to use it sparingly on both sides of the gasket to get a good seal. I've never seen it fail if used properly. Permatex #1 is also useful on leaking manifolds.
I'll look into that .
The color of the gasket maker was black ,almost looked like the bolts had gaskets. :)
   / metal piece came out of oil pan when changing oil #66
black rtv.. :)
   / metal piece came out of oil pan when changing oil #67
i once had to take an oil pan off that i swear the prev owner used windshield urethane to put on.. I had to pry and cut it off with a razor blade / scraper :(
the tube of goo surely cost more than the correct cheap cork pan gasket.. :( :(
with theat windshield urethane on there.. it surely didn't need the 22 pan bolts to hold it on as that baby wasn't going anywhere...
   / metal piece came out of oil pan when changing oil #68
Gasp! Correct and cork don't belong together in the same sentence, although cheap certainly applies to cork. I hate cork gaskets. :confused2:
   / metal piece came out of oil pan when changing oil #69
i like em.... they do what they are suposed to...
   / metal piece came out of oil pan when changing oil #70
from my experience the well designed cork gaskets that fail prematurely are ones that are over torqued or misinstalled in some fashion
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
90018 (A48082)
90018 (A48082)
Kubota SVL95-2 High Flow Cab Skid Steer (A55218)
Kubota SVL95-2...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
