metal piece came out of oil pan when changing oil
   / metal piece came out of oil pan when changing oil #51
luckilly that governor is real close to the oil sump.. likely it all fell out and went safely to the bottom.. like the titanic.. :)
   / metal piece came out of oil pan when changing oil #52
I tend to agree, everything may be ok unless a piece somehow managed to find it's way into the aluminum oil pump gear, which could be easily damaged.
   / metal piece came out of oil pan when changing oil #53
you'd already know by now.. same with the timing gear...
   / metal piece came out of oil pan when changing oil #54
G'day I want to know where all the balls went?????
Jon
Here are some pictures of some progress ,there were 2 balls left in the assembly and the remaining 8 were at the bottom . Things look good as far as no major damage to casings and gears. A little play in the oil pump gear between teeth on crank teeth.
   / metal piece came out of oil pan when changing oil #56
yep.. I figured they'd be inthe bottom...
everything came apart pretty good ,now I should clean everything up.Thanks .
I did notice a newer gasket sealer was used . This has been apart befor . I'll have to check out a gasket kit ,governor assembly ,case seal
   / metal piece came out of oil pan when changing oil #60
prev owner may have 'serviced' it and not put it back together correctly.. no keeper or something..e tc..
I just love taking something apart.. especially something delicate or expensive/difficult, and seeing rtv extruded out the sides of the case cover.. :)
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
2013 Audi A6 AWD Sedan (A55758)
2013 Audi A6 AWD...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55218)
2019 BOBCAT T630...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
BUNDLE OF 2" X 2" X 53" ANGLE IRON (A54756)
BUNDLE OF 2" X 2"...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
