Thank you all for the quick reponses : ) There appears to be conflicting opinions, and of course I put up the roof yesterday afternoon before I read these responses : ) but I put in just enough screws to get it on. Now I have to go up and put in the rest of the screws.
TexasJohn: I too thought that keeping the screws out of the valleys would help to keep the water away from the screws, so I went ahead and put them in every 4ft where the two sheets overlap on the ridge and every other ridge along the top and bottom and in the middle 2 rows in the ridges. I have alot more screws to do still : )
Eddie: I have read many of your posts and enjoyed them all! I can't believe you managed to build a lake! Wish I would have read this before I started : ) Too late to change what I have already done but I guess I had better put the rest of the screws in as suggested - two on one purlin, then one on the next on the flats.
I live in the Fraser Valley in British Columbia, Canada on 3 acres. We don't get very much snow out here. My pitch is 4x12 and I have included some images to show the front view and the side view. I know it is not a conventional way to do a pole barn - it started off as one 12x30ft- 3 stalls(10x12) then after I put in all the posts the neighbor came by and said I should make it bigger while I was at it, so I added more posts ending up with what appears to be 2 - 12ft x30ft buildings with a 4 ft space in between for an alley way, facing each other (my wife has named my attempt at a pole barn as "the Son of Frankenstien" - I couldn't stop adding posts : ). See attached pics.
The 2x6's really only span 12ft, cantilivered 2ft roughly in the center. Sitting on 2 - 2x10 girders nailed and bolted to posts with 2 - 1/2inch bolts in each and rafters attached to girders with hurricane ties. I will take some pics of my progress. Any advice is appreciated.
Mitch
