flusher
Super Member
- Joined
- Jun 4, 2005
- Messages
- 7,555
- Location
- Sacramento
- Tractor
- Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
flusher said:My 1964 MF-135 diesel is showing unusual oil pressure fluctuations. Oil pressure before this problem arose stayed in the 50-60 psi range constantly.
Now after engine start the pressure rises to 30 psi at 1300 rpm, fluctuates between 20-30 psi for 7-8 minutes and then drops to zero or near zero in about a minute. Shut off the engine immediately. Got a little coolant dripping out of the radiator overflow.
Repeated this behavior 3 times before stopping to think about the problem.
Checked the oil level; it's OK. Just a little oil leakage (less that a teaspoon) after engine shutoff, probably from the breather tube on the valve cover. No unusual smoke from the exhaust pipe.
The oil pressure gauge is a mechanical gauge with small diameter metal tubing to the engine.
Disconnected the oil pressure line at the engine and got a small pressure release and a little oil dribble from the fitting on the block.
There's a check valve on the outlet of the oil pump. Is this accessible by removing the oil filter plate on the block?
How about crankcase flush? Any recommendations?
Anybody have experience with Lucas Heavy Duty Oil Stabilizer?
Well, I finally found some time to work on the MF-135 oil pressure problem.
Decided to try the ATF flush method.
Got a nice new pressure gauge test kit from Amazon.com ($25) for measuring oil pressure and transmission pressure. Removed the oil pressure gauge that has the small diameter copper tubing and removed the oil pressure switch. The test gauge comes with a handy 4-ft hydraulic hose so you don't have to get off the tractor to read the gauge. Screwed the end of the hose right into the block.
Started the 135. Checked the oil pressure with the test gauge. Fluctuating between 10psi and 30 psi. Ran the engine for 15 minutes without any change in these fluctuations.
Drained the old 30W oil, removed oil filter. Added new 30W oil, new filter and 1 qt of Dextron ATF. Ran the engine at 1000 rpm for 10 minutes.
Pressure fluctuated as before between 10 and 30 psi. After about 3 minutes the pressure jumped to 60 psi and fluctuated between 30 and 60 psi for several minutes. Then the pressure evened out at 60psi. Shut down the engine after 10 minutes. Drained the oil, which looked like cream of tomato soup.
Replaced the oil filter, refilled with fresh oil. Ran engine for 10 minutes. Rock steay at 60 psi, which is where it was when I bought the 135 in July06.
I dodged a bullit on this one. Thought for sure I'd be replacing the oil pump. Was not looking forward to dropping that heavy oil pan.
