namyessam
I have done the 1400km return trip to try fix my tractor. Unfortunately it took longer than expected and so I have to go back again. I absolutely battled to get the head off. I had to use a crowbar and chisels and screwdrivers . It took me about 4 hours. Why dont they just make the clearance holes bigger. Anyway the gasket blew between one and two. However cylinder sleeve three seems to be cracked. I have brought the engine home with me so I can fix it at my leisure.
I am worried about two of the studs. There seem to be hairline cracks in the block . One of them seem to run into the cylinder sleeve.I am hoping that if I put in a semi finished liner it will not matter.
What have you guys who have rebuilt your engines do to make working on your engines easier. I am referring to an engine stand of sorts. I am wondering how to handle this motor safely when it comes to turning it around to do the crank shaft bearings. Can a waterpump be rebuilt. My cam is badly damaged where the fuel pump runs. Can this be built up with weld and machined?
Does anyone know of a write up of a diesel 135 I am hoping not to have to surf the net if someone knows of a good writeup. What should I be replacing in a rebuild ?If my head and crank and valves are okay would it be foolish to not do the waterpump and oil pump. I really dont want to throw money away but at the same time I dont want to do something foolish. My flywheel has cracks in it but I suppose this isnt a car .Can injectors be re serviced by a diy or is this highly specialized
Is there a solvent that gets rid of coke build up for the pistons and valves etc.
thanks eugene
I remember a thread you started some time ago and mentioned trying to find a service manual. If you don't have one, get one. you'll need it! I have been reading my manual on rebuilding this engine and WOW, there is alot of things that have a very specific way to be assembled and if done wrong will mean disaster. You mentioned about doing something foolish and not to insult you but not having a service manual would be a big one.
The injectors need to be service by a professional and could injure you if you inject diesel fluid in to your skin. The injector pump develops enough pressure to pierce the skin.
The water pump does appear to be rebuildable but a aftermarket rebuilt may be eaiser, cheaper and more reliable. I would make sure the oil pump is in perfect working order before reinstalling it since it is in the crankcase. It would be a major project to repair if you found it was not pumping the required pressure after the total rebuild. I would be more concerned about it than the waterpump unless it shows signs of leakage. Its on the outside of the engine and can be replaced easier than the oil pump. I believe DaButcher used fully finished cylinder liners that are dry sleeves. His thread has the instructions from "Hutch" how to remove them. I would have the valve seats checked by a good automotive machine shop before you reassemble it. It would be money well spent. Thats all for now
