namyessam
So far I have bought new semi finished liners, oil pump top and bottom gasket sets, rope seal and all new mains and big ends and thrust bearings as well as pistons and rings.MY end play is 0.4 mm on the crank and the spec is maximum 0.38. Can I fix this with oversize thrust bearings? tHE BOOK SAYS THEY ARE SOLD IN SETS OF 010,020,AND 030. I dont get this . How thick is 010? If I was aiming for 0.2 what size would I use and is there a specific way a thrust washer goes ( like forward for example Also I took the rope seal bearing holder out but dont know which half is on top or bottom. If you look at the halves one has a half moon scroll.Does the half with the half moon scroll go up or down?![]()
.010 .020 and .030 are inches. .010 is approximately .25 miillimeter. millimeter = inches X 25.4 or millemeter = inches divided by .03937 so .2 millimeter is about .0078 inches. So your endplay is .4 millimeter, take .4 divided by 25.4 and you get .0157 inches. using the .010 shim, you should have a maximum end play of .0057 inches or .14 millimeter, well within the spec of .4 millimeter. I'll do some investigating on the rope seal bearing holder.
namyessam
I really can't tell from agcopartsbooks.com which way this is assembled. Is there a visible stain on the block to indicate which way this came off? I have a feeling the part with the notch on the inside diameter is the top, I cannot be sure though. Did some more looking at the parts book and saw that +.007 sets of shims are available from agco. I now see that you will have to measure end play without the standard washers and recalculate the needed amount of washers since you need to keep the crank centered so you need equal amount in front and in back.
