MF188 generator regulator issue
   / MF188 generator regulator issue #1
Ausmac
Proserpine QLD
Massey Ferguson 188, JD 2130, Fiat 650
Hi guys, first post, hopefully it痴 in the right spot....
I have a MF188 that has been very reliable over the last two years. However now I need to get it registered so I have to get the lights etc working.
A while ago I replaced the generator but still have no battery charging input. Not sure how I test the regulator but thinking that could be the problem. As well, the key has been bridged to a push button start, no lights work, cut wires here and there, so if I could find a good wiring diagram I figure I will just rewire the whole lot front to back. Any help on the above issues would be much appreciated. Thanks!
   / MF188 generator regulator issue #2
Check the price on a new wire harness, they are quite cheap for MF 100 series, do you have a modern generator or the old dynamo type?
Mine has the generator/dynamo type. It is brand new, figured I would try and keep it the same so there would be less wiring changes. Hindsight tells me now that I should致e went the alternator route and changed the wiring anyway. Thanks for that info on the loom though, didn稚 know you could get a loom for something that old. Thought I壇 be doing the old individual wire trick.
2021 Kubota SVL75-2 Track Loader (A61306)
2021 Kubota...
17307 (A55853)
17307 (A55853)
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59905)
2022 KAUFMAN 2 CAR...
