MiG welder: how thick can it weld?
   / MiG welder: how thick can it weld? #21
By the way, a MiG is a Russian fighter which probably doesn't make good welds. :D:D:D
Says who?
Pics of my Russian MiG: :D
Larry
   / MiG welder: how thick can it weld? #22
My next project is to build a trailer to trailer my ISEKI G-174.....My new Lincoln 125 amp 20% duty cycle 110 /120 volt is my new toy and has no gas option....or should I say if I buy the gas valves etc....I think this unit is A/C input and DC output....my only question would be...."What" speed...(like dial setting) ....or would trial and error....or just plain practice be the answer I'm lookin' for....I'm usin' 0.35 wire that came supplied with the unit...I owned a gas/flux mig welder unit about 2 years ago that was made in Italy....I didn't care for it at all....so I returned it and bought a O/A Harris copy(China Made) this set sort off blew up(caught fire) my fault for not checkin' the tip as it mentioned to just finger tighten the tips....Hmmmm....so much for that idea.....so I went with the Victor copy so far so good.....first thing I check now is the tip for tightness before turning on the tank valves....anyhow I'm all ears on this mig welding subject....my first welding job a couple days ago....I welded the wire to the brass tip....that sucker is welded better than the metal I was weldin'.... yes and alot of splatter...that is also tough to remove....so I'm confident this little portable will weld what I need to weld....just need practice....and a little knowledge....yes I bought the auto darkening helmet....Thanks guys.....Ampa :thumbsup:
There is no way in the world I would build a trailer to transport anything at speed with a 120 volt unit. I have been welding for years and have yet to see a 120 volt unit that could do that job.
Chris
   / MiG welder: how thick can it weld? #23
I have a miller 135 110v mig that I like a lot but at only 10% duty cycle, unless I'm only tacking up some work, it gets to be problematic. Duty cycle, btw, is how many minutes per hr you can safely weld. So 10% is 6 min per hr. I'd spend the dough and get a good 220 machine. Also, get a good autodimming helmet. It will make life much easier for you. I'm going to either the 211 or 252 Miller to get a superior machine. Spend some time at millerwelds.com Their instructional videos are excellent. I wouldn't worry about welding 1/2" in one pass necessarily. In a previous life I made a living as a welder. It is not uncommon to just layer one course on top of another to fill a weld and be able to control the heat, penetration, and general quality/appearance.
I have a Syncrowave 180 for Stick and tig which I intend to turn into a mig welder via sale/purchase. The 180 is a nice machine but my eyes and lack of practice have made tig about unbearable for me now. There was a time I could make any welding test anywhere and I was a hand with tig...but you don't just walk up to it and do quality work:(...so mig is where it is at for me today. Practice, practice, practice!
Duty cycle rating is, the time you may weld in a 10 minute interval without overheating the unit. 30% duty cycle = weld for 3 minutes and rest with the unit on [fan running] for 7 minutes. Always keep the fan running even if the unit shuts down the welding circuit to keep it cooling.
   / MiG welder: how thick can it weld? #24
I must be lucky....I put together a trailer to haul a slide in camper that I removed from my little Ford Ranger before I sent the truck to the bone yard....I had this camper packed with all kinds of stuff....and it was heavy....I done all the welding with that Italian made mig welder....and the only pieces that came apart were bolted so it didn't cause any problems....I agree a 220 stick welder would be the correct way to go....but like I mentioned on one of my threads..... my lady and I just rent....and I can't justify installing an outside 220/240 volt box to build just one trailer......I do have an Italian guy that builds custom trailers and has done welding for my snow ploughs....I could just tack it together without loading anything on it to trailer it to him to weld it correctly....probely cost me a lot less than buying a stick welder and installing the 220/240 outside box receptical....I think this would be the best route to go....Thanks for the info.....Ampa
   / MiG welder: how thick can it weld? #25
Ampa... your "tip to work" distance (stick out) should be around 3/8".
if you melted the wire to the tip, then you must have touched the tip to the metal you are trying to weld.
remember that the Cu tip is going to be hot (live) when you pull the trigger. try this; have the wire sticking out of the tip around 3/8 to 1/2", touch the wire to the metal, then pull the trigger.
I wouldn't be welding a trailer until you are a little more experienced.
also, if the wire you are using says AWS class E71T-GS on it, it's mostly intended for static loading and sheet metal work I.E. hand rails, fenders, hobby crafts and such.
it is not intended for dynamic loading, as it has no requirements for impacts... especially at low temps.
thus, you can use it on some parts of a trailer, but not all.
you may want to save up for a AC/DC stick machine so you can cover most situations. you'll need 220 V supply though.
good luck.
If you are welding the wire to the tip, one of three things is wrong.
Too much heat for the stock thickness.
The wire speed is too slow and allowing the arc to burn back to the tip.
You are holding the tip too close to the work.
   / MiG welder: how thick can it weld? #27
yes, there is a E71T-11 class, but that is not the class that comes with the 110 V welders. also, it is a multiple pass electrode, but it is still limited (not recommended) for thickness greater than 3/4" metal.
unless it's static, I would not use it in a deep groove weldment. and then, I still would not use it. if you need a self shield wire, a T-8 would be a better choice, but you will need a larger machine.
it may look like FC runs hotter than solid wire, but 200 amps is 200 amps.
typically a core wire will have better penetration and higher deposition than a solid wire because of the make up of the wire. the metal sheath that surrounds the flux allows for a higher current density at a specific amperage. however, DCEN wires will have less penetration than that of a DCEP wire. that being said, it will weld better on thinner material.
   / MiG welder: how thick can it weld? #28
Well durnit, all this talk about welding and Mig weldres went and peaked my curioscity, so I walked over to the neighbors, he's the one who has welders, not the other neighbor who has the biting poodle I can't stand.
So, as I was saying, I walked over there, and asked a lot of questions. I was thrilled when he let me weld with his mig welder thing, and I tell you once I got past being scared of what was going to happen when I pulled the trigger I actually welded some metal onto the other metal from the nozzle things. This welding thing is just amazing. With less than 5 minutes of practice I was a welder.
Now if its that simple to weld, why don't more people do it. Turns out according to my neighbor dang near anybody can as long as they can hang onto the gun thing and pull a trigger. He was right nothing to welding at all. You just set two hunks of metal side by side, line up on that sucker and fill the middle in with weld stuff.
Then came the highlite of the evening. My neighbor, the good one, not the one with the poodle pulled out his newest toy. We even had coffee as he showed me this new invention. It's real easy since his house has a walkout basement and his shop is in the basement, he just intercoms upstairs to the woman and she puts the coffee service in the dumbwaiter he built with all his machinery & tools and it's right there in the basement in a jiffie. I was looking at the dumwaiter and thinking I could make one, but I don't even think I'd be well off intercoming the wife for anything. I don't have a walkout basement either so everything would have to come into my shop thru the living room, and Elsa would probably pitch a hissie.
Where was I, oh, the new toy. He has this welder that is battery driven and slicker than slick 50. You can carry this little welder anyplace, well out inthe rain might not be a good idea, and I forgot to ask about welding the boat dock, but just about anyplace, and he says you can weld anything with it. He was going to show me how it worked but the battery needed to be recharged. Ain't that always the way with rechargable tools. So I'm going ot go back over with a little project I been bending up, and try out that battery welder. He says its made by Hobart. That's real easy to remember cause Hobart stands for Hobby + art. I couold get me one of them battery welders and set up a booth at the flea market, and probably make my investment back in no time. Lord knows investing in the stock market never came out good for me.
   / MiG welder: how thick can it weld? #29
The best thing about those little MIGs is that they often come with cool laser guides!!
Paint em green and yeller an you can build space ships.
Hey (removed)....about that poodle...ground a piece of sheet metal and play tug with the torch.
   / MiG welder: how thick can it weld? #30
Can a 110 volt MIG weld a trailer?
My answer: sure, IF the steel is 3/16 inch thick or less, and IF the weldor (the person welding) is competent, and IF the steel has been properly prepped (cleaned, wire brushed).
Example: The frame on my travel trailer is made up of 1/8 thick flats, welded to make a fabricated I-beam. The spring hangers are directly welded to the bottom "flange" without any reinforcing gussets at all. Not the best design...one of the spring hangers ripped off, taking the lower flange with it. I did part of the repair with my 220 volt Hobart Handler 175, but had to turn the voltage way down to avoid burning through. This was using 0.035 solid wire and 100% CO2. Eventually the wind picked up, I set the Hobart aside and grabbed the old Lincoln Weldpak 100, loaded with 0.035 fluxcore. It still has more than enough "oomph" to burn through. (Duty cycle is not a real problem for me, I'd weld a minute or so, stop and check things out, clean slag, put out the fires in the grass or my socks...)
Would I trust the 110 volt Lincoln to weld 3/8 inch plate on a trailer? NO WAY! As alluded to earlier, the problem is this: The welder only can deliver a certain amount of heat. The thicker material acts as a heat sink, soaking up the heat from the weld. If the weld is limited in power, there's incomplete fusion because the steel can't be heated up enough. Multiple passes don't do any good either.
There was a very good thread on this on the Welding Web site a year or so ago, complete with graphs, charts, and pictures of cross-sections of welded joints. Their general consensus was that a 110-volt wire-feed, with proper techniques, could weld 3/16 inch thick adequately (meeting requirements). 1/4 inch was marginal. Above 1/4 inch was not feasible.
2019 Ford F-350XL (A53314)
2019 Ford F-350XL...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
Giyi Mini Log Splitter (A53316)
Giyi Mini Log...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
