Mitsubishi D2000
/ Mitsubishi D2000 #1
ebyrd10000
I bought a D2000 has a 2 cylinder Ke130 motor I have been having a problem with white smoke out of the exhaust and oil residue spraying out..Tractor seems to run find to me not sure my first diesel not sure how it supposed to be.. It starts everytime no problem runs without getting hot just the whitish smoke and oil out of the exhaust..The motor seems to maybe have a bit of a sputter when i press the gas but i am not sure if that is how this 2 cyclinder is always supposed to be any help would be appreciated...
/ Mitsubishi D2000
update ...thought I might start with a compression test and then check the glow plugs....while i have the injectors out is there anything i should check for?
/ Mitsubishi D2000 #3
i do not think that is how it is suppose to work.black soot out of the exhaust could be normal. the white smoke could just be the condensation in the exhaust and should clear up when the exhaust gets hot. the oil spilling out the exhaust could be a problem.the sputtering also may be a problem.it should work smooth when you accelerate.try some injector cleaner in the fuel.this may clean out the injectors and solve your problem.
/ Mitsubishi D2000
thats what I thought just never owned a 2 cyclindder diesel before..
/ Mitsubishi D2000
I have a product called diesel purge coming going to try a injector flush anyone else ever tried this?
/ Mitsubishi D2000 #6
Ive seen these problems get pretty deep in the past. Where did you get this machine?
/ Mitsubishi D2000 #7
i added some diesel injector cleaner last year in my fuel. i dont remember the name but i got it from a auto store. how was the compression tests?did you put on some good hours of running on the tractor? i did 6 hours on mine last week.moved 20 yards of dirt and dug up some stuff. z old beast worked nice.
/ Mitsubishi D2000
got the machine from a neighbor seemed fine when I drove it home...
I just got the compression tester from harborfreight today and plan on taking it this weekend..
/ Mitsubishi D2000 #9
good luck on the tractor.how long did you run the tractor? waiting to hear what you find.when a lot of machines sit for long periods the fuel gels up in the jets and prevent fuel from flowing efficiently. so with the use of additives in the fuel you could purge out the gels and chances are it could work fine.the compression test would give you the condition of the head ,head gasket, rings,cylinder,pistons.if you have good compression on the cylinders the engine may just have a fuel related problem.which could range from the parts starting at the tank ,the fuel lines,the filter,the injector pump,the injectors.the glow plug is just a pre heater and has no bearing on the engine performance.it just aids in starting.
/ Mitsubishi D2000 #10
ebryrd -
Having read your other thread about oil coming out the exhaust:
How many hours on the engine?
What type of hours?
Diesel engines are subject to "wet stacking"
Wet stacking - Wikipedia, the free encyclopedia
so if the engine was underused it might be suffering from that. Try googling wet stacking.
/edit - and it's kind of a rule around here that new tractors have pictures posted so we can say "ooh" and "ah" :)
/ Mitsubishi D2000
it has 300 hours..I did that diesel purge flush and now seem to have more oil coming out of the exhaust..Maybe the cleaner also washing out all the soot in the exhaust?
/ Mitsubishi D2000 #12
I have read about this problem here and several other forums. One solution is to put the engine under a load and work it pretty hard. If you have a plow, tiller or some attachment that you could use to do this, you should give it a try and see if the smoke stops. If not, you may have some other problems like worn rings.
/ Mitsubishi D2000 #13
ebyrd10000. if the tractor starts up nicely and runs like a champ and the only problem is a little soot from the exhaust i would not be too worried because as you work this tractor for many hours running it at about 1000 rpm and above while hauling and ploughing.the exhaust may eventually clear out.make sure you have a clean air filter in there and there is no obstruction in the air passage.i have heard that some guys run kerosene in the diesel engine and they have found that it burns cleaner for them.
/ Mitsubishi D2000
i have cut the exhaust off band routed it to the ground I got tired of being covered with oil.Tractor runs ok but my exhaust is still plumming and when i shutt it off and come back there is oil on the ground under the exhaust pipe where i pointed it to the ground. maybe half a table spoon worth of oil??
/ Mitsubishi D2000 #15
You might want to do a google search on "wet stacking" and read up on this. If wet stacking is not your problem then you've probably got worn rings.
/ Mitsubishi D2000 #16
that do not sound like a good working engine. the oil through the stack is too much. you probably have worn rings. or more likely valve seals wear. or some engine head problem.the valve guide in the head could be worn.only way to fix it would be to rebuild the thing.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2014 Acura MDX SUV (A59231)
2014 Acura MDX SUV...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
FUEL CELL (A58214)
FUEL CELL (A58214)
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
