marrt
Platinum Member
I’m building a new deck on my house. Due to the complexity of the design, I am building part of the deck on a temporary structure. This will allow me to suspend the deck posts of their holes and pour concrete up to the bottom of the post. This makes getting the post in exactly the right spot, and getting it level in the right spot, much easier. Because I’m doing this myself, I would like to avoid a lot of concrete mixing if possible. I know that some people use a fast setting concrete and simply pour the bags of concrete into the hole dry and then add water. You can’t get much easier than that. However, while I’m sure this isn’t as good as premixed concrete, is this technique good enough for a deck? On the concrete sites where this technique is discussed, the examples given are for fence posts, basketball goals, mailboxes, etc…. They don’t talk about a load bearing structure such as a large deck. Any opinions on this approach?
