Mk Martin snowblower hydraulic deflector
   / Mk Martin snowblower hydraulic deflector #11
JD1435. Same platform as this machine. I don't have a cab. No need for one. My broom has a rubber lip on the top which acts as a deflector.
   / Mk Martin snowblower hydraulic deflector #12
I couldn't bring myself to pay $550 for the hydraulic deflector from the dealer last year when I purchased the blower. After one winter clearing the driveway at our place, that seems to always be windy, I had had enough of that. Bought a 2 inch bore 6 inch stroke hydraulic cylinder from tractor supply. 2 90 degree fittings, 2 half inch to 3/8 reducers, 2 3/8 flow restrictors, 2 8 foot 3/8 hydraulic hoses, and 2 pioneer fittings. I've got a little over $200 into this and will be money well spent once the snow starts flying again.
What are you controlling it with?
Are you going to power the rotate function of the chute as well?
I ordered the blower with the hydraulic chute because I knew I wanted that and it was coming in the winter. Needed it usable right away. My tractor came with 2 remotes in the back. I added Multiplier from summit to use a 3rd. I have one set for my hydraulic top link and can switch between the rotation and deflector from the other remote by pushing the button
   / Mk Martin snowblower hydraulic deflector #14
I did this last year with Amazon components on my 68'' MK Martin, I also added a dual remote setup on my tractor too as a necessity.
   / Mk Martin snowblower hydraulic deflector #15
Nice build!
I was in the same boat 10 years ago when I bought my Woods SS74 blower. They wanted $675 for the hyd. chute rotator and deflector package. I had an open station tractor at the time and it wasn't a big deal to reach back and work the chute manually, so I passed.
Fast forward a few years when I bought a cabbed tractor. Working the chute now meant getting on and off the tractor. I began to wish I had spent the money when I originally bought the blower. I searched but found the hyd. chute was no longer available for the SS74.
I searched a bit more and found this Woodmax combo chute and rotator kit for $475:
It wasn't much work to modify it to fit the Woods SS74. A piece of 6" channel iron and a few odd parts were all that was necessary.
Adding the deflector cylinder to the chute was the hardest part. I had to cut off the existing brackets and re-weld them in a different location:
The project took around 8 hours and IMO, it was time & money well spent. I can blow snow from the cab in a T shirt without having to put my Carhart's on to get out and make adjustments.
Life is good again! :)
   / Mk Martin snowblower hydraulic deflector #16
I'm looking to copy your setup. This is great! With the 3/8" hose and the flow restrictor, how is the speed on the deflector? Would you go more flow to speed it up or is it perfect? Do you happen to have a video of the setup in action?
   / Mk Martin snowblower hydraulic deflector #17
I'm looking to copy your setup. This is great! With the 3/8" hose and the flow restrictor, how is the speed on of the deflector? Would you go more flow to speed it up or is it perfect? Do you happen to have a video of the setup in action?
Sorry, no video available. I haven't needed the blower for the last 2 seasons due to lack of snow. Early predictions are, I won't need it this year either.
I started with .045 restrictors but the action was too fast, so I replaced them with .030's. With those, it takes around 5 seconds to turn the chute 270 degrees. It takes about 2 seconds for the deflector to fully articulate. This will vary from tractor to tractor though due to variations in flow rate.
In both cases, I'm cautious to not hit the stops for fear of stripping the sheet metal gear on the chute or bending the cylinder mounting tabs on the deflector. I need a crossover relief valve with a lower set pressure to prevent this but so far, I haven't found one. I tried to find the valve used on the Woods kit but the part is no longer available. The Woods SS74 is so old now, "for parts" units are showing up and I may have luck finding one.
   / Mk Martin snowblower hydraulic deflector #18
Thank you for the reply. My apologies for any confusion, I'm interested in newkiotiguy setup as I have the MK Martin Pull type as well.
2013 BMW 528i (A53424)
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A56138)
2012 INTERNATIONAL...
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
