Model L and Model C Repower Parts
   / Model L and Model C Repower Parts #21
The 5000/Pro hi-lo planetary is not as strong as the original L planetary but iut is good enough. I have a 5665 that has 3000 commercial hours on it. The bushings were worn and the ring gear noisy but that is it. Gravely thought that the new style planetary was strong enough to handle 16 HP. To date they have been right.
   / Model L and Model C Repower Parts #22
getting ready to do my 2nd repower, I'm picking up a dead L8 Gravely that the engine is wore out on. That way it will live another life instead of being parted out.
   / Model L and Model C Repower Parts #23
The last time I priced out a modest repower, I could buy a low hour Pro8 for less...and so I did. I bought a low hour Pro8 with 30" deck and sulky for $350.
I also priced out a 16 HP Vanguard repower. By the time I figured in the exhaust system, engine, adapters, wiring, ignition switch, etc etc, I could buy a Pro16 for less so that is what I did.
There is a down side to the old L planetaries and new engines. That planetary was designed around an engine that spun at a maximum of 2400-2600 RPM. Modern engines spin at 3600 RPM which means that the ground speed and attachment speed will be about 50% faster.
Lowering the governed RPM isn't really an option. If a modern engine is reset to a maximum of 2600 RPM the power it can generate generally drops dramatically. Typical is a 30% loss in power. That means that a 12 HP engine will only produce 8 HP. Having said that, a new 12 hp engine producing 8 HP@2600 RPM will outperform a worn out Gravely engine. I would venture a guess that most old worn L engines are actually producing about 4 HP...maybe less.
It is these all of these issues that caused me to dump the L8 (Super Convertible) I had. I would get all done and still have the same failure prone PTO linkage, the same battery box and hood issues and more.
Don't forget to add a dipstick and increase the amount of oil in the transmission.
My advice is to weigh the pros and cons carefully before starting a project like this.
   / Model L and Model C Repower Parts #24
The 13 HP ?Honda clone has max torque at 2500 RPM, and is pretty flat up to that. 13 HP Gas Engine With Recoil Pull Start : Carroll Stream Motor Company : www.carrollstream.com Torque determines the "work " a engine can do. HP is how fast it can do it. No one cares how fast a tractor is, they used to be rated by "drawbar Pull". There is an old racing adage that says " torgue wins races and HP sells cars", thats why you never saw a 1.6 L engine in a race pontiac GTO or chevy chevelle. Even tho back in the 80s Toyota had formular atlantic engines that produced 900 HP and up. All that said the Honda clones come with wiring, a switch, and everything new and the efficiency of a new cross flow overhead valve head sips fuel compared to the old flat heads, I would bet the gas savings at over 15 bucks for 5 gallons would more than pay for the adaptors over the life of the engine. 100 gallons doesn't take very long if it's working every day.maybe 200 hours at working throttle speed ? And... it sure is nice running at 3600 throwing 2-3" of snow 75 feet at a very fast walk/ slow run. Or a regular weekly mowing job done in 1/2 the time.with a 42" instead of a 30"deck.all the while still using less gas! I maybe would have bought the pro 8 for 350 bucks too, ran it till it blew up and then dropped in a honda/ honda clone and never looked back. But more likely I would have bought yer old blown up gravely for100 and dropped in a new jap engine and started enjoying the fuel savings and reliability right away. and sold the old engine for 100 bucks as a rebuildable core to someone that just has to have an original, gas guzzling ,quirky,antique, trailer queen.
   / Model L and Model C Repower Parts #25
I can find no torque/rpm chart for the Chinese engines. I can only assume that the torque curve is the similar to a Honda. According to what I see on Honda engines, the torque curve actually drops off above 2500 RPM. It may be OK when run at 2400 RPM. Hard to say without some evidence.
I will concede the power point in this case but I do appreciate the link to the 13 HP Chinese engine. I have known about Carrol Stream engines for a while. I am more than a little skeptical about them. I cannot find any longevity data for those engines. I do foresee some problems with them as the cooling fan is made from a white plastic. As a general rule, white plastic does not hold up to sun light and will get brittle and fail is short order when compared to black plastic. In general I fall back on the adage that states "You get exactly what you pay for" and "quality comes at a price".
Just to give you an idea what $350 will buy, here are some purchases I made this year.
- A 16G with 50" deck for $350 It had dirt in the needle/seat.
- A Pro 8 with 30" deck and sulky for $350 (including gas to pick it up) It needed a battery.
- Two 4 wheel tractors for $350. One is a 8129 and the other is a 8162-B. Both came with good/fair 50" decks. Both of them run well. I had to put an exhaust valve in the K301 before it would run well. All I did was put gas in the 8163-B and it ran.
- I can't remember what I paid for my 5665 with steering brakes. I think I paid about $400 for it. It needed a new condenser.
Now you see why I dumped the L8. When I can get a newer tractor that runs for about the same money as an engine, it makes the L8 not worth messing with.
For the record, I traded the L8 for a old style brush. I didn't want to part out the L8. Had I done that I would have been left with a large casting and a bunch of parts that I would have to take to the scrap yard and that is a pain.
   / Model L and Model C Repower Parts #27
I have 3 carroll stream engines, a 13 HP on a professional 12 gravely used mostly for snow blowing and brush cutting 3 years and going at temps down to - 20F(adapted with Bruce's help) , a 16 single cylinder that replaced a 20HP 2 cyl briggs on a sears lawn tractor used mostly as a Tug / box scraper, and a 16 that replaced a 18HP briggs twin on a leaf vacume / trash blower 12" vac thing, that runs 8 hours a day for 2 months a year( it's 2 years old). I don't use Stabil ( I shut the fuel off and run them dry) and they all always start and fuel use on all of them is less than before I swapped. I have no problem with carroll stream engines and parts are interchangable with honda at any local honda dealer, the colors are even the same. I have never even changed a spark plug, just oil. I see no dif. in the 16HP CS and the 18 and 20 HP B&S they replaced, and at the price I can buy more than 2 for 1.
   / Model L and Model C Repower Parts #28
I wouldn't buy them for 50 bucks unless I was going to repower them. the Ls used gas like a toilet flushing.
   / Model L and Model C Repower Parts #29
I wouldn't say that. If I recall correctly, I could get about 5 hours of running time per tank of gas (2 gallons) using my Father's L tractors. This was cutting heavy grass with a 30" deck. I would start about 9am with a full tank, run it until noon, break for lunch, then run it for another hour or so before it would run out of fuel.
   / Model L and Model C Repower Parts #30
I've got a "project" L sitting in the barn, that I want to repower eventually, so follow these repower threads with interest....
Haven't worked all the details out yet, but have been thinking about adding a reduction gear set between the "modern" engine (I would choose a diesel clone) and the gravely transmission. Add a 2" or so oil filled gear case with set of gears or chain/sprocket in an oil bath at say a 35% reduction in speed throughput.
That would lower the ground speed in low range of an L model, and make the high speed (which is usualy too high for most tasks anyway) more usable, and at the engines designed rpm band. You could also offset the engine up, down or over if desired.
Down side would be a similar reduction in the pto speed, but that shouldn't hurt anything except a cutter deck?
Presently working on a diesel repower of a Deere zero turn M665 and a couple other things, but hope to putter around with this some more soon.... Any thoughts on if this would work? (the Gravely, not the zeroturn - I KNOW that will work! :D)
Oh and the other Gravely project is adding steering brakes to the L!
2018 Kubota L2501 (A53317)
2018 Kubota L2501...
UNUSED PABREAK BE232 HYD BACKHOE DIGGER ARM (A57193)
UNUSED PABREAK...
UNUSED SDLANCH SDLD25 CRAWLER DUMPER (A57192)
UNUSED SDLANCH...
2007 CATERPILLAR D5G XL CRAWLER DOZER (A52707)
2007 CATERPILLAR...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
(2) USED 700 LB TRAILER BRAKE AXLES (A57192)
(2) USED 700 LB...
