Mouse SMELL
   / Mouse SMELL #1
wedge40
Had a mouse build a nest in my car cabin filter and it had babies. One or more died. I've changed the cabin filter, pulled the blower motor and cleaning it out good. Still smell's like dead mouse. Is there a way to clean out the vents without tearing my car completely apart? Got some sort of bag in the car that's suppose absorb smells, but still stinks.
It's only be a little over a week, will time heal this?
Wedge
   / Mouse SMELL #2
   / Mouse SMELL #3
Had one die in my truck. I stuck the end of the leaf blower in the door and let it run about 30 minutes. Didn't completely clear the smell but it sure helped it a lot.
   / Mouse SMELL #4
Had one die in the insulation of the kitchen oven, after 2 years of use, had to buy a new one. Smell never went away. Good luck.
   / Mouse SMELL #5
I had a mouse beheaded in the squirrel cage blower so I had to pull the motor. They entered the system through the air intake as I found stored dog food in the filter box. You could still have a dead mouse somewhere in the duct system. When I removed mine the smell was gone.
   / Mouse SMELL #6
I keep d-con packets in the trunk, engine compartment and under the driver's seat. I started doing that when I spotted wires with chew marks in the engine compartment. Nice part about d-con, mouse dies from that they only smell slightly and not for long, mostly just a "musty odor".
Harry K
   / Mouse SMELL #7
I had the same problem with mice and the cabin air filter. Finally, I installed some wire mesh on the air intake above that filter, under the cowl. It was difficult but worth the effort. My vehicle is a Toyota Highlander but I'm sure there are other cars where there is easy access to the ventilation system.
PHil
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
XCMG CV83PD (A53317)
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
Deere 335P (A53317)
Deere 335P (A53317)
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
