Moving logs, tree debris, etc. w/BX2360
/ Moving logs, tree debris, etc. w/BX2360 #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
We had several pines dropped last year and I want the mess cleaned up before Bigfoot (or similar creatures) move in. Not having tackled a job like this with my new machine, I was wondering if something like the BXPANDED forks (or similar) would be useful? I'd like something cheap, that would work well on the FEL but bear in mind I don't know how to weld.
Thanks!
/ Moving logs, tree debris, etc. w/BX2360 #2
I have cleaned up enough trees to get a good idea. I use my 5" chipper right on the spot. The larger wood is your choice 16" lengths for the stove or 12' to 20' for ???.
Craig Clayton
/ Moving logs, tree debris, etc. w/BX2360 #3
A toothbar on the FEL will help you be able to hold a 10 inch log on the bucket edge, I regularily move logs 10 inch by 9ft long over to wood pile to be cut and split later. Any bigger you will need to drag with three point hitch and chains or other sophistications .
Toothbar when angled slightly, will push many of the remaining branches away or into brush piles , the teeth randomly get caught into the branches while you push , then you lift up and you got a good bucket full, .....now of course forks will hold more , but will still only hold the same amount of weight when it comes to log size , in other words your bucket can only handle one fair size log anyway no matter how long the forks. Forks can hold more brush.
See your specs on your tractors about weight the bucket can lift , now imgaine that weight being further out on the forks , so then even less can be carried than the specs state.
/ Moving logs, tree debris, etc. w/BX2360 #4
Think about the Rad and other delicate parts that stay branches have an affinity for. They like protection.:thumbsup:
/ Moving logs, tree debris, etc. w/BX2360 #5
How far are you going to move this stuff?
/ Moving logs, tree debris, etc. w/BX2360 #6
Thanks!
Take a look at this old thread. Might answer your question.;)
http://www.tractorbynet.com/forums/...65-bx-takes-tornado.html?highlight=f1+tornado
/ Moving logs, tree debris, etc. w/BX2360 #7
If you want to go REALLY cheap, check out the elcheapo deluxe wood forks I made. I threw these together in 1/2 hour with scrap wood. They bolted into holes in the side of my bucket drilled for the toothbar. I reinforced the holes in the wood with a couple scraps of plywood. These were intended for a couple loads of moving brush but I used them all summer for moving logs, pallets, brush, tools, even the 8' x 8' walls of my cupola. I did eventually buy some steel forks but for the investment (zero $ and very little time) these worked great. I had a half dozen 6' long big oak logs on them at times. I couldn't believe they didn't break! YMMV
/ Moving logs, tree debris, etc. w/BX2360 #8
now that's good old fashioned ingenuity Radair
/ Moving logs, tree debris, etc. w/BX2360 #11
Any reason why you can't just push them with the loader? If it is only a few yards that should work. I would try it before spending time and money on something you might not need.
/ Moving logs, tree debris, etc. w/BX2360 #12
If your tractor has a hoe, check out The Bro-Tek Thumb at Bro-Tek: Tractor Add Ons, an amazing device for lifting logs, rocks etc. Just bought one and could not be more pleased. Good luck.
/ Moving logs, tree debris, etc. w/BX2360 #13
Not very far... a few yards. Planning on just getting it out of the way & stacking OR chipping up later.
I have owned a BX2200 and now a BX2660 and done a lot of tree brush work and I just push storm debris and cut trees to a ravine or burn pile. Forks would be handy if you were going to transport longer distances.
I will probably buy a set of pallet forks for our bigger Kubotas some day, but that will be for stacking or moving equipment and such.
/ Moving logs, tree debris, etc. w/BX2360 #14
Only a few yards away? I am surprised you havent attacked it yet with the BX. Just go and just start clearing it already. I would just move what you can scoop/push/scrape. Anything that is too big, just hop out and cut large branches in half OR connect with chain and pull out of the way. :thumbsup: My favorite type of seat time.:D
/ Moving logs, tree debris, etc. w/BX2360 #15
I use a set of forks that chain to the bucket. I have stacked logs and loaded and unloaded tons and the work very well and were cheap.
No reason at all! I am starting tomorrow.
Starting tomorrow. Now I did find a set of clamp on forks (600 lb. load limit each fork) made with USA steel for $149.00 that I am picking up as I will have to transport some of the junk further to a burn pile.
It's neat discovering just how much one of these things will do!
/ Moving logs, tree debris, etc. w/BX2360 #18
i got less expencive forks that clamp on with a higher weight limit but bent them lifting logs. becarefull which ones u buy
They are from Yankee Warehouse in PA. using Pittsburgh steel and AWS, PTL certified welds. We shall see.
/ Moving logs, tree debris, etc. w/BX2360 #20
Clamp forks really don't do the job plus they weight limit the lift do to distance from lifting arm.
Go grapple or go home!!! Better lift, and better control.
2005 GMC C7500 24FT BOX TRUCK (A59904)
2005 GMC C7500...
2006 Godwin GHP45KW-RC45kW Towable Generator (A59228)
2006 Godwin...
12' CONTAINER (A52706)
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
BOX BLADE (A58214)
BOX BLADE (A58214)
