Mx5100HST OR DK50HST OR 5035 MAHINDRA?
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #11
Blue gill, I started to buy a L3800 when I bought mine. I think I would of been a lot happier with those 6 extra horses. The 32hp is not enough for he HST in my opinion.
Makes sense.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #12
The M5100 is a Gear Machine that is stripped of Features found on the Kioti. Not a even match up.
The MX5100 is offered in gear and hydro.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #13
Don't forget, while your trailer has dual 3500 pound axles, you have to factor in the trailer weight itself, which is probably around 1500 pounds. So in theory, you can only put 5500 pounds on top, making the Mahindra too heavy. Both the Kioti and the Kubota will get you near the max weight also.
I have the same problem & I am planning to upgrade to a larger trailer as soon as I can afford it. My LS puts me right near the max weight also, just with the tractor, loader, and whatever I have on the loader. That doesn't include any extra attachments either.
As for the tractors, they are all good choices. The Kioti will give you the best value of the three.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #14
I decided with only 11 miles being the farthest I ever need to go, I didn't need another trailer "upgrade"... I have one it will fit that can't hold it and one that could hold it but won't fit... :mur:
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #15
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #16
DK50SE vs an MX5100? No comparison. You can probably get the DK50SE with a cab for the price of the 5100 and not have your loader contol pointing toward you.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #17
I still say if towing isn't among the primary objectives or a trailer upgrade isn't out of the question; the Mahindra would be the better dirt mover being the heavier machine. Another thing I forgot to mention, with dirt moving being a primary use for the machine, I'd go lay down and look at the front axles and compare how they're built. The front axle will be taking a lot of the stress moving earth, so that was something I checked out when making my purchase and was shocked at the differences in the 40HP class.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #18
I think the MX5100 with a loader and fluid in the tires will overload a 7k trailer.
   / Mx5100HST OR DK50HST OR 5035 MAHINDRA? #19
Any of them ballasted properly for dirt work with any sort of quality implements like a heavy box blade are easily going to overload it honestly. Who wants to make two trips or set and spin tires all day? :D
I agree, I don't like the loader control pointing at me, plus I think the kubota loader operates to fast. It's bad about dropping loads to fast and shaking the whole tractor. I do like the fact with kioti you can access both sides of the tractor.
(1) 24ft Free Standing Panel (A51573)
(1) 24ft Free...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
