I have some descent dealers around.
My L3200 has industrial tires.
Today, I am leaning towards the MX5100 because it has 42.5 pto, and the kioti only has 37.5, so that's another 5hp on the pto.
I'm ready to just flip a coin and just buy one. I'm tired of thinking about it.
FYI, the Mahindra 5035 also has 42.5 pto HP.
What do you plan on using anyhow that will require the extra 5 PTO HP ? I ask because my buddies L3540 has about 10 less PTO HP than my LS (28hp vs 38hp) but we pretty much use the same implements anyhow and his handles them just fine. Most PTO implements are 6 ft or less, 38.5 HP will handle them just as well as 42.5 will. My buddy pulls his 84" finish mower with his and handles it nicely.
I'm not challenging your choice, I don't think you can go wrong with any of those 3 tractors... I'm just thinking that basing your decision off +/- 5 PTO HP might not be the best factor, unless you truly need that additional 5 PTO HP to run something larger.
Really? Doing what, and with what tractor, implement, implement size & tractor HP? I have never once run out of PTO power... sheared plenty of shear pins, broke a PTO shaft... nearly buried an auger with my previous CK20 because I shot the auger down too fast but almost didn't have the 3pt lift strength to get it back up.I exhaust my PTO power way more often than I lose traction ....
I will not respond to aggressive posts.
Also implements over 6' get expensive.
agreed...For the same or similar money I can see wanting the extra 5 PTO horsepower when all else is equal, but if it meant paying much extra or going with something else of lesser spec, I could live with 5 less. I don't think you can go wrong with any of them.
Gman... check this out. It's the same blade I just picked up (can't believe there's 2 around here, I have half a mind to pick it up as a reserve!!! ). Blade works awesome. 8ft Heavy Duty 3pt BladeTell me about it...I'm looking at a 7' brush cutter, 7' scrape blade, and 7' rake to replace my 6-footers. The brush cutter would be a convenience, but the other two I'm just not happy with the smaller size, especially if you angle them.
