MX5400 cab compared to L5460 cab
   / MX5400 cab compared to L5460 cab #21
The front & optional rear cab lights suck. They are just a cheap halogen bulb with moderate light at best. A LED cube or mini-bar will do you a lot better & cost less than the $120 Kubota wants.
All the wiring is already there. You just need to plug in the switch & connect the wires to the lights. Connectors are a bit funky on the lights, so probably easiest to cut them off & put more common ones on.
I went way overkill on mine with new wiring, a new fuse/relay box & 46-52" LED bars. Might just have gone with mini bars on the stock wiring if i had it to do over again. Would take me an hour to install 4 maybe a hair more if I had to pop the roof the find the ends of the wires tucked up under there. https://www.tractorbynet.com/forums/customization/376458-let-there-light-l4060-light.html
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
2006 Acura RL Sedan (A55853)
2006 Acura RL...
2013 freightliner Altec D2050-TR Derrick Digger Truck (A52377)
2013 freightliner...
Brush cutter (A55973)
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
