My BX24 is urking me...
   / My BX24 is urking me... #12
My BX23 is 4 years and 1100 hours old.
Had the water in the 4 way flashers once&unpluged one wire off the switch for a week or 2 clipped the wire back on an it's never did it again.
Neutral start switch went bad was replaced when still in warranty never a problem again.
You must have got a lemon....mine is over a year old with NONE of those problems..knock on wood.
No elect electrical problems with either of the BX1500s
1 is new other is used.
   / My BX24 is urking me... #13
yikes ! :eek: right now i have BX 24 and i havent had any problems with it except backing it up into a tree and smashing the rear tail light:eek::rolleyes:. so far no electrical problems. however i can share your sympathy on the wiring on the BX24. when i added additional lights for nighttime clearing- i was disappointed on how small the wires were. so i added much heavier gauge wires for it to be on the safe side. I see you are in walworth somwhere just 10 mins south from me. :cool:
   / My BX24 is urking me... #14
BX-23
faulty limit switches on the start/safety system. had to walk home several times.
water in switches ... on a tractor .. you gotta be kidding ... bit I had it too! actually in several of them.
Some things on this machine are just fine ... the electrics and seat are not part of them.
   / My BX24 is urking me... #15
Have you ever found a mouse in your tractor. With that many problems there has to be somthing at work.
   / My BX24 is urking me... #17
WD40 is a good alternative if you are leaving your tractor outside often. Spray it into the switches to help repel moisture. It immediately solved the neighbor's B2620 problems!
IowaAndy
   / My BX24 is urking me... #18
i have own my bx24 for over 2 years with no electrical problems.hope you have better luck with yours.
Giyi Log splitter (A53316)
Giyi Log splitter...
Giyi Pile Hammer (A53316)
Giyi Pile Hammer...
10ft X 5ft Livestock Corral Panel (A55758)
10ft X 5ft...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
2014 Chevrolet Cruze Sedan (A53424)
2014 Chevrolet...
2013 Nissan Sentra Sedan (A55758)
2013 Nissan Sentra...
