My First Stick Welding Project
   / My First Stick Welding Project #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I bought myself an old tombstone AC welder and I am learning how to use it. This is my "ventilation" system plus I have the cellar door open a crack. Works good. I can see all the smoke going into the "hood" as I weld. I don't even set the smoke detector off and my wife says there is no smell upstairs.
Anyway, I thought I should do something that doesn't matter for a first project. But I wanted to do something heavy. So I built up some worn down plow shoes. Harmless enough. These are utilitarian welds not those of a craftsman. :) Doing this is a lot more interesting than just laying beads like I have been doing.
gg
   / My First Stick Welding Project #2
If you go to buy some 6011, I really like Hobart's 335A 6011.
   / My First Stick Welding Project #3
I agree. When my shop burned I replaced my Hobart rod with Radnor rod. Not impressed at all
That is Lincoln Fleetweld 180 (6011). An almost full 5 lb box came with the welder along with some 6013 and 7014 which I have not tried yet. The 6011 is just about gone now I might try the Hobart. I have been keeping everything the same so I can see if I am getting any better at it. Which I am, even thought you can see from my work I have a long way to go.
   / My First Stick Welding Project #5
A shop vac isn't really a substitute for a fume extractor as it can catch on fire.
   / My First Stick Welding Project #8
Looks like a very nice welding table GG! Way to dive in on a big weld... at least for some of us. Yeah not you, SA.
No argument from me on this. It is one of those Do Not Try This At Home Yourself things.
And yes I have two good size fire extinguishers within an arms length and I stay down in the shop for an hour after I am through welding to make sure everything is still good. I agree it is a very poor welding environment but it is better than out in the snow.
Thanks Dragoneggs. I built the table with my torch set along with some advise I got here. In the same "shop". It is one of the handiest things I have. I use it for everything it seems. It was my first major welding project.
gg
   / My First Stick Welding Project #10
Anybody know why we're getting so many double posts in the last couple of days? There must be a glitch in the system.
Second on Arc Weld. Also looks like you have a lot wood around that welding. Hope you have a big fire extinguisher.
Ron
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
VOLVO ECR25 EXCAVATOR (A60429)
VOLVO ECR25...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
UNUSED FUTURE...
