buckeyefarmer
Epic Contributor
Congrats!!!! That is a big door.
Just gonna bump Eddie's post here in case anyone missed it. I think this is a big deal, and a great catch.I couldn't find a picture, but you show it in this video. The stove pipe looks like it goes from single wall pipe, to double wall pipe where it goes through your roof. The open around around the pipe looks like it's framed out for a ceiling support box, but there isn't one installed.
Here is a picture of one. They come in a variety of sizes and finishes.
Dura-Vent DirectVent Pro Cathedral Ceiling Support Box - For Vent Pipes with a 4-Inch Inner Diameter - 46DVA-CS
Dura-Vent DirectVent Pro Cathedral Ceiling Support Box - For Vent Pipes with a 4-Inch Inner Diameter - 46DVA-CS When a direct vent pipe must pass through a ceiling, it requires a ceiling support box that serves as the bottom support for the entire installation. This support box has an adjustable...www.efireplacestore.com
Here is an article that talks about installation and shows the ceiling support box being installed.
Chimney Pipe Installation for Wood Stove Through a Flat Ceiling
Chimney Pipe Installation for Wood Stove Through a Flat Ceiling: Are you thinking about installing a wood stove? You will be able to install a wood stove with chimney pipe after reading this instructable and you can do the job with common household tools. Installing a Class A Insulated Double...www.instructables.com
That support box is not needed and is NOT a big deal. Dura-vent has many options that don't require it. Looks like he is using the below recommended setup for cathedral ceilings.
8'' DuraTech Roof Mount Support Kit - DT840-KIT
