My Industrial Cabin Build
   / My Industrial Cabin Build #3,132
One ton of AC extra for each window.
I don't understand this. From what I understand, HVAC sizing is based on the volume of the building. Ducts are placed to deal with the heat loss of windows, but I've never heard of increasing the size of a unit by how many windows you have.
The HVAC Contractor should have been consulted before construction started. He will size the unit and create a plan for the ducting, along with electrical requirements before anything was framed. Then when the house is sealed in, he shows up and installs everything after the electrical is roughed in, and before the sheetrock happens.
In my opinion, it's better to go with a unit that is slightly undersized, so it runs longer, then a bigger unit, that is always turning on all the time. Kind of like a car. You use less fuel when driving at a constant speed than you do when accelerating from a stop.
   / My Industrial Cabin Build #3,133
Well you build yourself a greenhouse, and an insulated house with no windows. Size your AC according to square footage, and see which one is livable. Build both the same size with same amount of AC.
   / My Industrial Cabin Build #3,134
I think accuracy is somewhere between your theory and Eddie's. I don't think I need to add a Ton of AC for a bathroom window for example.
   / My Industrial Cabin Build #3,135
That's why the HVAC guy does a heat loss-heat gain study first before the building is even built.
Its not really how many windows you have but the quality and the install of them that counts.
AS they say"Install is everything".
   / My Industrial Cabin Build #3,136
I have to agree, a ton of AC per window would mean we need 25 ton of AC! Never heard of this - its about the building heat loss (for heating) and similar for cooling. Our HVAC contractor calculated for heating we needed 75-78K BTU at 5* F so we installed a 72BTU FHW boiler 11 years ago and never had an issue.
On the AC side, we have 2 Mitsubishi Mini Splits a 12K and a 9K, so not quite 2 Tons and this cools the house fine in the summer. Of course this is NH, so in the south or warmer climates more cooling will be needed, but most typical houses are a 3-5 ton units.
I think David is going with Mini Splits for cooling mainly in the BR's and main living area, at least that was the plan.
   / My Industrial Cabin Build #3,137
I just built houses for a living. I don't know nothing.
   / My Industrial Cabin Build #3,138
Never said you didn't know anything. Just looking for middle ground. My Builders were awesome. But they let an HVAC expert design and install our system.
   / My Industrial Cabin Build #3,139
You got jokes. I misunderstood and thought you were being serious. I get it now. :)
[QUOTE="Carl_NH, post:
I think David is going with Mini Splits for cooling mainly in the BR's and main living area, at least that was the plan.[/QUOTE]
That is still the plan. I have been doing my calculations based on area, btu output, and making adjustments for high ceilings, tight building with full insulation, and thermal mass of the floors. It’s gonna be fun.
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2002 Wacker RD11A Tandem Smooth Drum Roller (A55851)
2002 Wacker RD11A...
BRADCO HP600 COLD PLANER (A52707)
BRADCO HP600 COLD...
