My letter to Kioti, loader rerepair, long
Status
Not open for further replies.
   / My letter to Kioti, loader rerepair, long
Yes. I agree. This is why I am encouraging all owners to check for cracks and then follow through with your dealers or Kioti if you find cracks. Even if your warranty has expired.
Maybe Kioti can identify a bad run by serial numbers, maybe identify a design problem, maybe engineer a repair bulletin or "kit" to be added as reinforcement.
(We're up to the 16th most highly viewed Kioti own/op post ever.)
I am being somewhat selfish here by trying to get the problem solved for all cracked loaders since I will likely have a cracked up loader before long. Even after my warranty expires I will use the Kioti engineered fix at my cost.
   / My letter to Kioti, loader rerepair, long #263
I spoke with my dealer today and they are getting my loader reinforced and told me I won't even be able to see the repair when it's done. He was talking to the Kioti Rep and he said they have only fixed 3 of these so far . That's in Canada. I will send a Pic of the repair when I get it back Friday.
   / My letter to Kioti, loader rerepair, long #264
   / My letter to Kioti, loader rerepair, long #265
Did they explain what the repair would be exactly? Just curious since I'm in the same boat. Although my craks are only about 1/2" right now.
   / My letter to Kioti, loader rerepair, long #266
   / My letter to Kioti, loader rerepair, long #267
I just got my CK30 back, They had a 3/8" plate made to fit over the entire back of the loader which was welded on . The plate had the hole in the back water jetted out so it looks good. They then made the inspection cover out of another 3/8" plate and tapped the six holes out to 1/2". They then painted it and it looks great.
I will send a pic as soon I borrow camera.
   / My letter to Kioti, loader rerepair, long #268
3/8"! /forums/images/graemlins/shocked.gif That's pretty thick to be adding to that 1/16" thick base metal. Do you have a brushguard? Clearance is tight so you'll want to be sure you don't have contact there.
Wow, please post the pics.
Status
2015 Ford F-550 Mason Dump Truck (A56858)
2015 Ford F-550...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
2019 CATERPILLAR 259D SKID STEER (A52709)
2019 CATERPILLAR...
New/Unused Electric Golf Cart (A57453)
New/Unused...
