My letter to Kioti, loader rerepair, long
Status
Not open for further replies.
   / My letter to Kioti, loader rerepair, long
Yes. I agree. This is why I am encouraging all owners to check for cracks and then follow through with your dealers or Kioti if you find cracks. Even if your warranty has expired.
Maybe Kioti can identify a bad run by serial numbers, maybe identify a design problem, maybe engineer a repair bulletin or "kit" to be added as reinforcement.
(We're up to the 16th most highly viewed Kioti own/op post ever.)
I am being somewhat selfish here by trying to get the problem solved for all cracked loaders since I will likely have a cracked up loader before long. Even after my warranty expires I will use the Kioti engineered fix at my cost.
   / My letter to Kioti, loader rerepair, long #263
I spoke with my dealer today and they are getting my loader reinforced and told me I won't even be able to see the repair when it's done. He was talking to the Kioti Rep and he said they have only fixed 3 of these so far . That's in Canada. I will send a Pic of the repair when I get it back Friday.
   / My letter to Kioti, loader rerepair, long #264
   / My letter to Kioti, loader rerepair, long #265
Did they explain what the repair would be exactly? Just curious since I'm in the same boat. Although my craks are only about 1/2" right now.
   / My letter to Kioti, loader rerepair, long #266
   / My letter to Kioti, loader rerepair, long #267
I just got my CK30 back, They had a 3/8" plate made to fit over the entire back of the loader which was welded on . The plate had the hole in the back water jetted out so it looks good. They then made the inspection cover out of another 3/8" plate and tapped the six holes out to 1/2". They then painted it and it looks great.
I will send a pic as soon I borrow camera.
   / My letter to Kioti, loader rerepair, long #268
3/8"! /forums/images/graemlins/shocked.gif That's pretty thick to be adding to that 1/16" thick base metal. Do you have a brushguard? Clearance is tight so you'll want to be sure you don't have contact there.
Wow, please post the pics.
Status
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2016 Nissan Sentra Sedan (A56859)
2016 Nissan Sentra...
5ft 7in X 4ft Metal Fencing (A57454)
5ft 7in X 4ft...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
