My little ditch digger
   / My little ditch digger #1
mfrost
CA
JD 750
Picked up a KK Middle Buster yesterday at TSC and it works great! Got a couple pics for you to look at. Will be making a modification on the top link connection point on the impliment so it will go deeper than 9 inches. The nose levels out at that depth. As you can see I don't have rocks.:rolleyes:
   / My little ditch digger #3
i guess the clay helps 2...
cool pics btw
   / My little ditch digger #5
Larry239 said:
How many passes to get those results?
That's what I would like to know as well. Plus, how much bite was each pass and what size is your tractor? (okay, call me blind, just saw you have a 750 :eek:)
Steve
1st pass about 7 inches
2nd and 3rd pass about 1 inch each (due to cutting point leveling out)
You are looking at about a 10 inch deep ditch
After my mod this week end I think I'll be able to get 14 inches in 2 passes. Will let you know and will have pics.
   / My little ditch digger #7
If rocks were gold ..... I'd have a really nice tractor or 3 or 4.......;)
Let us know how the top link modification works out.:D
Well here are pictures of the mod. Did a little more than the top link change. Also decided to add a little weight to it. Take the front end weights and hang them on the back.. As for depth, I can get 12 inches now. Draft arms just about bottomed out.;)
Thanks, have about 6' more rail that I'm going to make more weights for the front end.;)
   / My little ditch digger #11
the local scrap yard had a huge pile of railraod stuff... rail, plates, spikes etc
   / My little ditch digger #12
MFrost, can you be a little more specific on your mods. I have the exact same buster and I like the mods you did. What size steel did you use? how high did you raise the top hole? how does your weight hanger work? what does the pin catch on, on the piece of RR steel? You did a nice job there and some slick looking welds, not your first time obviously. Thanks in advance.
   / My little ditch digger #13
Thats a good idea.
I added about 400# to my box blade and it really makes a difference for the better.
top link bracket is 1/2" x 6" plate with pin hole 2 1/4" higher and 4 1/2" farther back than stock.
Weight hanger is piece of concrete stake with 3/8" rebar welded to the end so the weight will not fall off in the ditch :rolleyes: Hope this helps
   / My little ditch digger #15
nice mods
why don't they make them this way.
with that said I would take off the sticker king kutter and give her a coat of green.
Picked up a guart of JD green when I got the buster. Usually wait a couple weeks after I do a mod because I usually think of something else to do to it. Maybe a cup holder will finish it off.:rolleyes:
   / My little ditch digger #17
That is a nice modification to a great tool. Unfortunately here in New England, we have too many rocks that would make the front end of the tractor stand up on end. :D
Dusty
   / My little ditch digger #18
Mfrost, nice work on your little ditch digger. What part of CA do you call home?
   / My little ditch digger #19
If I could lift those weights I wouldn,t need a stinking tractor.Seriously great job...Could you please explain how adding to the top link lets it dig deeper?It seems that depth is limited by the lower links.I tried to figure it out but I think my brain is fried from the "will it fly" thread.
   / My little ditch digger #20
Looks like we have a bunch of California guys on this thread. I lived in Antioch CA for around 30 years, (the arm pit of the Delta). Retired in Michigan where land is affordable and your neighbors are far enough away that you can throw a rock in any direction and not hit a house from your property line. Still have a ton of family in the Sacramento area.
I love the sub soiler mods. I have the same TSC sub soiler and have been racking my brains on how to get a little more depth out of it.
Farwell
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CATERPILLAR 305.5E2 CR EXCAVATOR (A60429)
CATERPILLAR...
Gravely ZT 1540 40in Zero Turn Commercial Mower (A59228)
Gravely ZT 1540...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
