This thread really has me thinking.
We purchased our new home in the fall. We are on 4.4 acres and it's heavily wooded. The previous owners never did anything to maintain the wooded part of the property and there is a lot of pine that is all dying at the same time, so it's a huge mess. I've been spending every free day I can out in the woods cleaning up dead/down trees and dragging out tons of partially rotten logs. That's meant a lot of fires. If I get home from work early enough, I'll start a small fire while I cut/split. Then on weekends, I start a fire first-thing in the morning and spend the entire day out there cleaning up and feeding the fire.
I grew up on a 1 acre lot in the country. My family and all our neighbors had burn pits and we would burn pretty frequently. Most people also had burn barrels for their trash. Because of that, I never gave it a second thought and I've never pulled a permit or talked to anybody about burning at the new house. Now, I'm reading our townships rules and it seems that I should have a permit and that they're only issued on specific days (The 2nd and 4th Saturdays of the month between December 1st through August 31st). You can't burn anything larger than 6" diameter, the fires can't last more than 5 hours, and must be out (no smoke) by 6:00 PM. They specifically say no burning on Sundays.
I had a couple of friends over a few weeks ago and we spent the day cutting wood. We had a fairly large fire going, and the sheriff drove down the neighbors drive (it runs parallel to ours on an easement at the edge of our property) and sat and watched us tossing logs (whole ~10-14" diameter rounds) onto the fire for about ten minutes. At about the time I was going to walk over there and strike up a conversation, he left. Now that I'm reading the rules, I am assuming he was trying to decide whether to ding me for the "open fire" without a permit. Worse, I worry that a neighbor called him or the fire department. I don't want to have a bad relationship with local law enforcement, the fire department, neighbors, or anybody else.
The local ordinances do allow "recreation fires." They must be in an "approved" ring, outdoor fireplace, or burn pit. There is a size restriction (I've been exceeding it), and a big list of things I can't burn (there's probably a fine line between brush and kindling...). I have made crude stools out of some pine logs that I use around the fire pit. I think that I'll dig the current fire pit up in the spring (It's probably a 6-8' diameter circle of rocks) and re-position the rocks into a 3' circle (the max size for a recreational fire). I will split everything over 6" diameter, so I'm never throwing whole logs on. The fires really are recreational for me. I'll work out there all day, then when the sun falls I sit on one of those stools for an hour or so and watch the fire/pet the dog/decompress. Still, I'm concerned about antagonizing my neighbors. I have years worth of frequent burning to do just to clean up the mess I already have.
