My New Kubota ZD1211 Mower
   / My New Kubota ZD1211 Mower #211
Here is a photo someone else posted in this forum couple of years ago (probably one of you?).
Apparently this is a typical newer RD deck.
I wonder how long these skids would last in a commercial use?
   / My New Kubota ZD1211 Mower #212
Brown Dog, Did you say that you also trimmed the center metal guard/deflector for the transmission? Have you gotten a chance to mow without the skids on?
   / My New Kubota ZD1211 Mower #213
I did Notch around the bolts on each side & trim about an inch off the metal brace in center.
I have not removed the two skids yet.
   / My New Kubota ZD1211 Mower #214
OK, I need to try that. Do you also find the "ride" of the mower to be very rough?
   / My New Kubota ZD1211 Mower #215
On rough ground yes it’s very rough.
I’ve mowed my place for 20yrs with a Farm Tractor & learned where all the holes are with this zero the last 3 summers.
   / My New Kubota ZD1211 Mower #216
A buddy with his Toro 60” SD Deck helped me mow here all evening today in Heavy Thick 6+ inch grass.
I had a firsthand experience with SD & RD clippings mowing at 3” back & forth : not in circles.
My RD left light clumps evenly spread out.
His SD left a 12” wide windrow with side chute flipped up out of the way.
Neither one looked good so I’m undecided lol
Sorry no pix.
   / My New Kubota ZD1211 Mower #217
Sorry no pix.
But, was the wind blowing and which one of you had more cut grass blow on you? Also which one of you had the choice of doing psycho mowing of circles and box mowing from outer edge to inner center or center inside box mowing in a square to outside edge? Traditional back and forth ends up with double cutting the same grass with SD where there is no double cutting of grass with RD so SD should leave finer cut grass clippings, not saying good or bad. Also SD can only cut close to objects on one side so only going in one direction and trees are usually round so SD will blow out a pile in a circle that has to be dealt with as well as limiting choices of mowing directions by only having one side for up close cutting.
I'm now sold on SD with mulching kit but getting ready to retest my ZD1211 RD myself today or tomorrow to see if grandson had it at full throttle the last time he mowed with it after just getting the machine.
   / My New Kubota ZD1211 Mower #218
Did you remove the rubber flaps and trim the center trans shield? Are you running Gator blades?
   / My New Kubota ZD1211 Mower #219
The SD Pilot did get covered with clippings.
I hate being limited to one direction with SD to keep clippings off of buildings & out of the road.
All of My Dang neighbors blow their clippings into the road : Burns Me Up !!!
   / My New Kubota ZD1211 Mower #220
I hope you are not planning to attack any of them like............
:eek:
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
Case Axial-Flow Combine Wheels NO RESERVE (A55315)
Case Axial-Flow...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
2013 JCB 3XX Backhoe (A55973)
2013 JCB 3XX...
